Hello Guys,
after upgrade the Website show confused content. Then I look around and find a few Entries with the same Problem, but the Solutions not help me. like this:
(HTML Broken after update to v2.9 - githubmemory)
I tryed many things, all modules was deactive but not looks better.
I deleted the module businessprocess because of the information.
now i need your help, what is the reason?
Here are the informations about my system.
Thanks in advance for your assistance.
Rico
These Updates was installed at Monday, after that the Problem appears.
update.txt (23.5 KB)
The IDO-Database is now also ready.
MODULE VERSION STATE DIRECTORY
cube 1.1.0 enabled /usr/share/icingaweb2/modules/cube
director 1.7.1 enabled /usr/share/icingaweb2/modules/director
doc 2.9.3 enabled /usr/share/icingaweb2/modules/doc
grafana 1.3.5 enabled /usr/share/icingaweb2/modules/grafana
graphite-web 0.0.0 disabled /usr/share/icingaweb2/modules/graphite-web
incubator 0.5.0 enabled /usr/share/icingaweb2/modules/incubator
ipl v0.5.0 enabled /usr/share/icingaweb2/modules/ipl
migrate 2.9.3 enabled /usr/share/icingaweb2/modules/migrate
monitoring 2.9.3 enabled /usr/share/icingaweb2/modules/monitoring
pdfexport 0.9.1 enabled /usr/share/icingaweb2/modules/pdfexport
reactbundle 0.7.0 enabled /usr/share/icingaweb2/modules/reactbundle
reporting 0.10.0 enabled /usr/share/icingaweb2/modules/reporting
setup 2.9.3 enabled /usr/share/icingaweb2/modules/setup
test 2.9.3 enabled /usr/share/icingaweb2/modules/test
translation 2.9.3 enabled /usr/share/icingaweb2/modules/translation
vsphere 1.1.0 enabled /usr/share/icingaweb2/modules/vsphere
vspheredb 1.1.0 enabled /usr/share/icingaweb2/modules/vspheredb
x509 1.0.0 enabled /usr/share/icingaweb2/modules/x509
icinga2 - The Icinga 2 network monitoring daemon (version: r2.13.1-1)
System information:
Platform: Ubuntu
Platform version: 18.04.6 LTS (Bionic Beaver)
Kernel: Linux
Kernel version: 4.15.0-156-generic
Architecture: x86_64
Build information:
Compiler: GNU 8.4.0
Build host: runner-hh8q3bz2-project-508-concurrent-0
OpenSSL version: OpenSSL 1.1.1 11 Sep 2018
Application information:
General paths:
Run directory: /run/icinga2
PHP 7.2.24-0ubuntu0.18.04.9 (cli) (built: Aug 16 2021 05:46:32) ( NTS )
