I installed the PDF export module and it fails to export with the following error:
I verified that I can output the version as suggested by the troubleshooting step at the terminal.
What could be wrong?
The browser opens a new tab with the error above. I tested creating a pdf headless on the terminal and it worked.
You may have to create an additional symlink as described here. Or install google-chrome, as chromium seems not to work.
The sym link did the trick. Thanks!
