In my host config I have
vars.mem_wused = "98%"
vars.mem_cused = "99%"
And in my service config I have
apply Service "Memory [Physical]" {
import "nrpe-generic-service"
import "service-override-24x7"
check_command = "nrpe"
vars.nrpe_command = "check_memory"
vars.memory_type = "physical"
if (vars.mem_wused == "" ) {
if (vars.mem_cused == "" ) {
vars.nrpe_arguments = [ "type=" + vars.memory_type, "warning=used>"+vars.mem_wused+"!critical=used>"+vars.mem_cused+"!empty-state=unknown" ]
assign where host.vars.os == "Windows" && host.vars.nrpe == true
I know my IF is not working, what am I doing wrong ?
What I want to do, it’s if under the HOST i don’t set the variable, inside the apply, it will override something…
