So i have been trying to use some other checks for quite a while now. Problem is that any of those always return UNKNOWN - check_nwc_health timed out after 45 seconds
I dont really understand the issue here, as this plugin is preinstalled/configured right?
i also dont really know how to go any further from here, as i looked through all parts of the director, and the way i understand it, is that you dont have to configure it manually bc the director does it for you, am i right?
Any help would be great, i think iam just missing a logical step here, or atleast i cant see the bigger picture from where iam rn.
If you need anything regarding my environment/config, please let me know.
Thanks in advance, and stay healthy.
Director version: ??
Icinga Web 2 modules:
director doc incubator migrate monitoring setup test translation
Does anyone have a clue on why that is, or how i can fix this?
Plus: I read into the docs regarding “working with agents” → they say you have to import THE agent template, but there is none preconfigured. Are these docs outdated, and if yes, where can i inform myself about all these informations
And where do i put the community string? Im working with director and i dont see a option for it. As well as the option where the command should run, if i manually enter the neccessary code part into the config it will be overwritten by director right?
