If I try to send it manually a notification works fine. The problem is that the notification shows as been sent and interval works too as I can see is sending more notifications but actually nothing is being sent.
Can you assist?
Using latest Icinga2 and IcingaWeb2
Figured it out.
the user did not have types = [ Problem, Recovery ] defined
Now seems to be working fine but only for services.
I think is because of the states listed. I will try to add Up, Down as well as states next to the OK, Warning, Critical
I was right. The states Up, Down have to be listed in the user states as well to be able to send notifications for hosts too.
