Good Morning,
i am a little bit confused: when i use “icinga2 node wizard” on a client, the Wizard doesnt start. Only the config compiler starts and icinga2 is running after that with the following output:
root@cesrv0064:/etc/icinga2# icinga2 node wizard
[2020-11-27 09:09:19 +0100] information/icinga-app: Icinga application loader (version: r2.1.1-1)
[2020-11-27 09:09:19 +0100] information/icinga-app: Loading application type: icinga/IcingaApplication
[2020-11-27 09:09:19 +0100] information/Utility: Loading library 'libicinga.so'
[2020-11-27 09:09:19 +0100] information/ConfigCompiler: Adding include search dir: /usr/share/icinga2/include
[2020-11-27 09:09:19 +0100] information/ConfigCompiler: Compiling config file: /etc/icinga2/icinga2.conf
[2020-11-27 09:09:19 +0100] information/ConfigCompiler: Compiling config file: /etc/icinga2/constants.conf
[2020-11-27 09:09:19 +0100] information/ConfigCompiler: Compiling config file: /etc/icinga2/zones.conf
[2020-11-27 09:09:19 +0100] information/ConfigCompiler: Compiling config file: /usr/share/icinga2/include/itl
[2020-11-27 09:09:19 +0100] information/ConfigCompiler: Compiling config file: /usr/share/icinga2/include/command.conf
[2020-11-27 09:09:19 +0100] information/Utility: Loading library 'libmethods.so'
[2020-11-27 09:09:19 +0100] information/ConfigCompiler: Compiling config file: /usr/share/icinga2/include/command-icinga.conf
[2020-11-27 09:09:19 +0100] information/ConfigCompiler: Compiling config file: /usr/share/icinga2/include/timeperiod.conf
[2020-11-27 09:09:19 +0100] information/ConfigCompiler: Compiling config file: /usr/share/icinga2/include/plugins
[2020-11-27 09:09:19 +0100] information/ConfigCompiler: Compiling config file: /usr/share/icinga2/include/command-plugins.conf
[2020-11-27 09:09:19 +0100] information/ConfigCompiler: Compiling config file: /etc/icinga2/features-enabled/checker.conf
[2020-11-27 09:09:19 +0100] information/Utility: Loading library 'libchecker.so'
[2020-11-27 09:09:19 +0100] information/ConfigCompiler: Compiling config file: /etc/icinga2/features-enabled/mainlog.conf
[2020-11-27 09:09:19 +0100] information/ConfigCompiler: Compiling config file: /etc/icinga2/features-enabled/notification.conf
[2020-11-27 09:09:19 +0100] information/Utility: Loading library 'libnotification.so'
[2020-11-27 09:09:19 +0100] information/ConfigCompiler: Compiling config file: /etc/icinga2/conf.d/commands.conf
[2020-11-27 09:09:19 +0100] information/ConfigCompiler: Compiling config file: /etc/icinga2/conf.d/downtimes.conf
[2020-11-27 09:09:19 +0100] information/ConfigCompiler: Compiling config file: /etc/icinga2/conf.d/groups.conf
[2020-11-27 09:09:19 +0100] information/ConfigCompiler: Compiling config file: /etc/icinga2/conf.d/notifications.conf
[2020-11-27 09:09:19 +0100] information/ConfigCompiler: Compiling config file: /etc/icinga2/conf.d/services.conf
[2020-11-27 09:09:19 +0100] information/ConfigCompiler: Compiling config file: /etc/icinga2/conf.d/templates.conf
[2020-11-27 09:09:19 +0100] information/ConfigCompiler: Compiling config file: /etc/icinga2/conf.d/timeperiods.conf
[2020-11-27 09:09:19 +0100] information/ConfigCompiler: Compiling config file: /etc/icinga2/conf.d/users.conf
[2020-11-27 09:09:19 +0100] information/ConfigCompiler: Compiling config file: /etc/icinga2/conf.d/hosts/localhost.conf
[2020-11-27 09:09:19 +0100] information/ConfigCompiler: Compiling config file: /etc/icinga2/conf.d/hosts/localhost/apt.conf
[2020-11-27 09:09:19 +0100] information/ConfigCompiler: Compiling config file: /etc/icinga2/conf.d/hosts/localhost/disk.conf
[2020-11-27 09:09:19 +0100] information/ConfigCompiler: Compiling config file: /etc/icinga2/conf.d/hosts/localhost/http.conf
[2020-11-27 09:09:19 +0100] information/ConfigCompiler: Compiling config file: /etc/icinga2/conf.d/hosts/localhost/icinga.conf
[2020-11-27 09:09:19 +0100] information/ConfigCompiler: Compiling config file: /etc/icinga2/conf.d/hosts/localhost/load.conf
[2020-11-27 09:09:19 +0100] information/ConfigCompiler: Compiling config file: /etc/icinga2/conf.d/hosts/localhost/procs.conf
[2020-11-27 09:09:19 +0100] information/ConfigCompiler: Compiling config file: /etc/icinga2/conf.d/hosts/localhost/ssh.conf
[2020-11-27 09:09:19 +0100] information/ConfigCompiler: Compiling config file: /etc/icinga2/conf.d/hosts/localhost/swap.conf
[2020-11-27 09:09:19 +0100] information/ConfigCompiler: Compiling config file: /etc/icinga2/conf.d/hosts/localhost/users.conf
[2020-11-27 09:09:19 +0100] information/ConfigItem: Validating config items (step 1)...
[2020-11-27 09:09:19 +0100] information/ConfigItem: Committing config items
[2020-11-27 09:09:19 +0100] information/ConfigItem: Triggering OnConfigLoaded signal for config items
[2020-11-27 09:09:19 +0100] information/ConfigItem: Evaluating 'object' rules (step 1)...
[2020-11-27 09:09:19 +0100] information/ConfigItem: Evaluating 'apply' rules...
[2020-11-27 09:09:19 +0100] information/ConfigItem: Evaluating 'object' rules (step 2)...
[2020-11-27 09:09:19 +0100] information/ConfigItem: Validating config items (step 2)...
[2020-11-27 09:09:19 +0100] information/ConfigItem: Dumping config items to file '/var/cache/icinga2/icinga2.debug'
[2020-11-27 09:09:19 +0100] information/ConfigItem: Checked 1 Endpoint(s).
[2020-11-27 09:09:19 +0100] information/ConfigItem: Checked 1 Zone(s).
[2020-11-27 09:09:19 +0100] information/ConfigItem: Checked 40 CheckCommand(s).
[2020-11-27 09:09:19 +0100] information/ConfigItem: Checked 2 NotificationCommand(s).
[2020-11-27 09:09:19 +0100] information/ConfigItem: Checked 3 TimePeriod(s).
[2020-11-27 09:09:19 +0100] information/ConfigItem: Checked 1 CheckerComponent(s).
[2020-11-27 09:09:19 +0100] information/ConfigItem: Checked 1 FileLogger(s).
[2020-11-27 09:09:19 +0100] information/ConfigItem: Checked 1 NotificationComponent(s).
[2020-11-27 09:09:19 +0100] information/ConfigItem: Checked 2 HostGroup(s).
[2020-11-27 09:09:19 +0100] information/ConfigItem: Checked 3 ServiceGroup(s).
[2020-11-27 09:09:19 +0100] information/ConfigItem: Checked 1 Host(s).
[2020-11-27 09:09:19 +0100] information/ConfigItem: Checked 11 Service(s).
[2020-11-27 09:09:19 +0100] information/ConfigItem: Checked 1 User(s).
[2020-11-27 09:09:19 +0100] information/ConfigItem: Checked 11 Notification(s).
[2020-11-27 09:09:19 +0100] information/ConfigItem: Checked 1 ScheduledDowntime(s).
[2020-11-27 09:09:19 +0100] information/ConfigItem: Checked 1 UserGroup(s).
[2020-11-27 09:09:19 +0100] information/ConfigItem: Checked 1 IcingaApplication(s).
[2020-11-27 09:09:19 +0100] information/DynamicObject: Restoring program state from file '/var/lib/icinga2/icinga2.state'
[2020-11-27 09:09:19 +0100] information/DynamicObject: Restored 82 objects
[2020-11-27 09:09:19 +0100] information/ConfigItem: Triggering Start signal for config items
[2020-11-27 09:09:19 +0100] information/ConfigItem: Activated all objects.
What could be the fault? How can i start the Wizard?
Best regards
Habit
