Hi all!
Having a bit of a strange issue. I don’t get any plugin output for one host, and only for that one host.
The plugin is check_iftraffic64, the checks work fine on other hosts.
It was working fine during the “testing” phase (finding the right plugin and parameters). After it was working on the cli, I went to the director and made all the ckeck and service templates in the GUI.
And now comes what probably is/was the issue:
When i created the check command I accidentially clicked “Icinga Check Command” instead of “Plugin Check Command”
At this point in time i only had that one host/service using this check command. In Icinga Web it showed me the icinga stats (as expected when using the Icinga Check…). At this point i changed the check command to the Plugin Check command type and since that i don’t get any plugin output for that host.
I created some other hosts using this check after i changed the check command type, all of them are working fine.
Maybe there is some cache or state file which needs to be deleted to get some output again? (maybe /varcache/icinga2)
Looked into the debug log, but no errors in there. Just that the check ran
Other things i tried:
Deleting the host in director and cli
Restarting the Icinga2 Service and der Server itself
Environment:
- Version used (
icinga2 --version
icinga2 - The Icinga 2 network monitoring daemon (version: 2.13.2-1)
Copyright (c) 2012-2022 Icinga GmbH (https://icinga.com/)
System information:
Platform: CentOS Linux
Platform version: 7 (Core)
Kernel: Linux
Kernel version: 3.10.0-1160.62.1.el7.x86_64
Architecture: x86_64
Build information:
Compiler: GNU 4.8.5
Build host: runner-hh8q3bz2-project-322-concurrent-0
OpenSSL version: OpenSSL 1.0.2k-fips 26 Jan 2017
Application information:
General paths:
Run directory: /run/icinga2
Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /var
Internal paths:
- Operating System and version
CentOS 7.9 - Enabled features (
icinga2 feature list
Disabled features: compatlog debuglog elasticsearch gelf graphite icingadb influxdb influxdb2 opentsdb statusdata syslog
Enabled features: api checker command ido-mysql livestatus mainlog notification perfdata
Icinga Web 2 version and modules (System - About)
Config validation (
icinga2 daemon -C
No errors, only some warnings for unused apply-rules -
If you run multiple Icinga 2 instances, the
zones.conf
file (oricinga2 object list --type Endpoint
andicinga2 object list --type Zone
) from all affected nodes
Only one instance
