" No Module Named Pymongo" even though I have pymongo installed
I have installed pymongo using pip and when I manually run the plugin to check the status of my mongo servers, it is working properly . in icinga status says No module named pymongo
anyone faced this issue before please help
When you manually execute a plugin you need to do this as user nagios or icinga (depending on you distribution) to find out what’s wrong or missing.
thanks for your quick response .<3
