Hello community,
after last Icinga2 update (2026-10-28) the email notifications nevermore working.
Before the updates the ‘Problem’ email notifications would received.
What I did: (on the Icinga2 host and other monitored hosts)
apt update
apt upgrade
After the update the ‘Recovery’ email notifications would never sent.
(should be sent to local root and an external email-address)
For testing purpose a monitored host would be shut down.
cat /var/log/icinga2/debug.log | grep Problem
[2026-11-02 15:36:30 +0100] information/Checkable: Checkable 'HOST.internal' has 1 notification(s). Checking filters for type 'Problem', sends will be logged.
[2026-11-02 15:36:30 +0100] notice/Notification: Attempting to send notifications of type 'Problem' for notification object 'HOST.internal!mail-icingaadmin'.
[2026-11-02 15:36:30 +0100] debug/Notification: Type 'Problem', TypeFilter: Acknowledgement, Custom, DowntimeEnd, DowntimeRemoved, DowntimeStart, FlappingEnd, FlappingStart, Problem and Recovery (FType=32, TypeFilter=511)
[2026-11-02 15:36:30 +0100] debug/Notification: User 'icingaadmin' notification 'HOST.internal!mail-icingaadmin', Type 'Problem', TypeFilter: Acknowledgement, Custom, DowntimeEnd, DowntimeRemoved, DowntimeStart, FlappingEnd, Flappi
[2026-11-02 15:36:30 +0100] information/Notification: Sending 'Problem' notification 'HOST.internal!mail-icingaadmin' for user 'icingaadmin'
[2026-11-02 15:36:30 +0100] information/Notification: Completed sending 'Problem' notification 'HOST.internal!mail-icingaadmin' for checkable 'HOST.internal' and user 'icingaadmin' using command 'mail-
host-notification'.
Result: No email notification.
Script mail-host-notification.sh would be tested:
/etc/icinga2/scripts/mail-host-notification.sh -d test -l $HOSTNAME -n $HOSTNAME -o test -r ``monitoring@FQDN.TLD`` -s test -t test
Result: Email sent.
What I also did:
su - postgres
psql -U icingadb icingadb < /usr/share/icingadb/schema/pgsql/upgrades/1.6.0.sql
Restarted icingadb and icinga2.
No changes with desired notifications.
The Icinga WebInterface show the missing host and services.
System Information of the Icinga2 Master:
root@icinga2:~# icinga2 -V
icinga2 - The Icinga 2 network monitoring daemon (version: r2.16.6-1)
System information:
Platform: Debian GNU/Linux
Platform version: 13 (trixie)
Kernel: Linux
Kernel version: 6.12.113+deb13-amd64
Architecture: x86_64
Build information:
Compiler: GNU 14.2.0
Build host: runner-aa2jha3hm-project-575-concurrent-2
OpenSSL version: OpenSSL 3.5.7 9 Jun 2026
Application information:
root@icinga2:~# icinga2 feature list
Disabled features: command compatlog elasticsearch gelf graphite influxdb influxdb2 journald livestatus opentsdb otlpmetrics perfdata syslog
Enabled features: api checker debuglog icingadb mainlog notification
root@icinga2:~# icinga2 daemon -C
NO errors reported.
Now I have no more ideas. I need somebody’s help.
Regards L.
