Hi Team,
I am getting the below error. I am using Icinga version 2.13.2-1. I have configured this as Icinga satellite and got this error while enabling the monitoring module from the webui. Can anyone help in resolving this error?
Hi Team,
Well you need to configure a backend in configuration of the icingaweb2.
I think with backend it means the icingaweb2 DB under the URL /icingaweb2/config/resource
and then select it under /icingaweb2/config/general
- alternatively you can use the config files under /etc/icingaweb2/
Hi, Backends are already added and the validation is also successful. Still I am getting the above error.
I see a mismatch. In resources, you have icinga_ido
and icingaweb_db
but icingaweb2
from “Access Control Backends” is missing.
