I am not able to deploy any services
please include more context in your question, something like
I have installed Icinga with version XY. I’ve created the following objects in Icinga Director version 1.2.3, and now I’m encountering the following problem: …
Has anyone seen this before and can help me please?
Btw, I’m running on Distribution XY, and am using PHP 7.1, in case that matters.Cheers & thanks,
Throwing in some picture and text won’t attract many readers, just saying
If you read the error message, you would notice that the host either uses an host template that doesnt exist anymore or the host is used as template somewhere.
Without further information, no one will be able to help you, beside tellling you to drop director database and recreate a new one
