Monthly creation of Report stored locally on System
Hey, hope someone can help.
In IcingaWeb I have currently entered reports with special filters that should be sent by email. Unfortunately it is not possible as a PDF, but at least CSV can be generated.
Because PDF is not possible, I’m trying to take a detour and would like to have the CSV saved monthly locally on the system on which Icinga2 itself is installed. Unfortunately I can’t find an option. Is there a way to have the report that I have defined generated locally via the console via IcingaWeb as a CSV and write it to an output file?
Platform: SLES
Platform version: 12-SP5
Disabled features: compatlog debuglog elasticsearch gelf influxdb livestatus opentsdb perfdata statusdata syslog
Enabled features: api checker command graphite ido-mysql mainlog notification
Hi @ilovekittens, welcome to the community.
There will be a download cli command with the upcoming release of Icinga Reporting.
