Monitore Icinga
Hello All,
I’ve got a Question very simple but I don’t find, can you tell me what all we can monitore with Icinga please ? Is it possible to list the different possibility please ?
You can monitore what ever you want. :wink:
Please check the docs https://icinga.com/docs/icinga2/latest/doc/10-icinga-template-library/ to get an overview.
Hello Hendrik,
Ok thanks I will check the link. Can you tell me if it’s possible to check an URL and we can log on this one . Can you tell me ho to do that please ?
Thanks for your help.
start here for the basic principles and continue here for specific examples.
Please refer to the docs, get an overview and try to develope your environment.
You can monitore every URL with check_http from the ITL.
