I have setup a single master, multiple agent environment (v 2.11).
zones.d
├── master.srv.com
│ ├── api-users.conf
│ ├── commands.conf
│ ├── constants.conf
│ ├── downtimes.conf
│ ├── groups.conf
│ ├── hosts
│ │ ├── agt01t.srv.com.conf
│ │ ├── agt02t.srv.com.conf
│ │ ├── agt03t.srv.com.conf
│ │ ├── agt04t.srv.com.conf
│ ├── notifications.conf
│ ├── services.conf
│ ├── templates.conf
│ ├── timeperiods.conf
│ └── users.conf
├── global-templates
│ └── commands.conf
Where master.srv.com is my master zone and ZoneName = master.srv.com.
Content of zones.d/master.srv.com/constants.conf
const LocalPluginDir = "/usr/local/lib/nagios/plugins"
Content of global-templates/commands.conf
object CheckCommand "memory" {
import "plugin-check-command"
command = [ LocalPluginDir + "/check_mem" ]
arguments = {
"-u" = {
set_if = "$mem_used$"
description = "Check USED memory"
"-f" = {
set_if = "$mem_free$"
description = "Check FREE memory"
"-C" = {
set_if = "$mem_cache$"
description = "Count OS caches as FREE memory"
"-w" = {
value = "$mem_warning$"
description = "Percent free/used when to warn"
"-c" = {
value = "$mem_critical$"
description = "Percent free/used when critical"
vars.mem_used = true
vars.mem_free = false
vars.mem_cache = false
vars.mem_warning = 80
vars.mem_critical = 95
On my agent I got the error, from /var/lib/icinga2/api/zones-stage/startup.log:
critical/config: Error: Error while evaluating expression: Tried to access undefined script variable ‘LocalPluginDir’
Location: in /var/lib/icinga2/api/zones-stage//global-templates/_etc/commands.conf: 10:15-10:28
/var/lib/icinga2/api/zones-stage//global-templates/_etc/commands.conf(8): import “plugin-check-command”
/var/lib/icinga2/api/zones-stage//global-templates/_etc/commands.conf(9):
/var/lib/icinga2/api/zones-stage//global-templates/_etc/commands.conf(10): command = [ LocalPluginDir + “/check_mem” ]
/var/lib/icinga2/api/zones-stage//global-templates/_etc/commands.conf(11):
/var/lib/icinga2/api/zones-stage//global-templates/_etc/commands.conf(12): arguments = {
icinga2 daemon -C doesn’t complain about anything. Why is the constants.conf not synced to my agents?
And one more question, is it a good practice to define the zones in the host.conf files like I did.
Content of zones.d/master.srv.com/hosts/agt01t.srv.com.conf
object Zone “agt01t.srv.com.conf” {
endpoints = [ “agt01t.srv.com.conf” ]
parent = ZoneName
object Endpoint "agt01t.srv.com.conf" {
host = "agt01t.srv.com.conf"
log_duration = 0
object Host "agt01t.srv.com.conf" {
import "generic-host"
address = "172.28.28.5"
display_name = "SRV-APP01 (Test)"
vars.os = "DEBIAN"
vars.partitions["disk /"] = {
disk_partitions = "/"
vars.http_vhosts["http"] = {
http_ssl = true
http_host = "agt01t.srv.com"
http_uri = "/info"
vars.load_wload1 = 5
vars.load_wload5 = 4
vars.load_wload15 = 3
vars.load_cload1 = 10
vars.load_cload5 = 6
vars.load_cload15 = 4
vars.procs_warning = 250
vars.procs_critical = 400
vars.agent_endpoint = name
Thank you for your feedback.
