This morning when I ran an “apt update” and reboot on the Icinga2 server, I was welcome with a ton of UNKNOWN messages for “snmp-interface” and “snmp-storage”. After some detective work, I found out that I had included some arguments in the past to the file, /usr/share/icinga2/include/command-plugins-manubulon.conf, and that the patch update overwrote those changes.
Is it possible that the following arguments can be included?
object CheckCommand "snmp-interface" {
arguments += {
"-q" = {
description = "Extend perf that will check the error and discard input/output"
set_if = "$snmp_interface_extperf$"
AND
object CheckCommand "snmp-storage" {
arguments += {
"-r" = {
description = "Do not use regexp to match NAME in description OID"
set_if = "$snmp_noregexp$"
