poncho
July 29, 2020, 2:21pm
1
We have several cloud servers running which get dynamically started or stopped on demand to save money. Thus it’s normal that some servers are down.
Is it possible to check something like “check all those services, be OK if OK_SERVICES_COUNT > X”?
Is there are check that checks results of a set of other checks?
rsx
(Roland Sommer)
July 29, 2020, 2:37pm
2
Hi & welcome to the icinga community,
You can create a check as described here or use check_cluster .
poncho
July 29, 2020, 3:20pm
3
Perfect. Works for hosts and services. Thank you.
poncho
July 31, 2020, 12:12pm
4
If someone is interrested. This is my solution to monitor a hostgroup of dynamic servers:
Host:
object Host "fis-bamboo-agent-gitc-linux-cluster" {
check_command = "dummy"
vars.dummy_state = {{
// Get all UP hosts in bamboo-agent hostgroup except this
var up_nodes_filter = function(node) use(host) {
"bamboo-agents" in node.groups && !match(host.name, node.__name) && node.state == 0
var up_nodes = get_objects(Host).filter(up_nodes_filter)
if (len(up_nodes) >= 1) {
return 0;
} else {
return 2;
vars.dummy_text = {{
// Get all hosts in bamboo-agent hostgroup except this
var nodes_filter = function(node) use(host) {
var nodes = get_objects(Host).filter(nodes_filter)
var up_nodes = nodes.filter(node => node.state == 0)
var output = "Cluster (" + len(up_nodes) + "/" + len(nodes) + " up):\n"
for (node in nodes) {
output += node.name + ": " + node.last_check_result.output + "\n"
return output
Services:
template Service "template-service-cluster" {
var service_name = macro("$name$").replace("-cluster", "")
var up_services_filter = function(node) use(host, service_name) {
"bamboo-agents" in node.groups && !match(host.name, node.__name) && get_service(node.name, service_name).state == 0
var up_nodes = get_objects(Host).filter(up_services_filter)
return 0
} else {
return 2
var services_filter = function(node) use(host) {
var up_service_filter = function(node) use(service_name) {
var nodes = get_objects(Host).filter(services_filter)
var up_nodes = nodes.filter(up_service_filter)
output += node.name + ": " + get_service(node.name, service_name).last_check_result.output + "\n"
return output
apply Service "procs-bamboo-agent-gitc-cluster" {
import "template-service-cluster"
assign where host.name == "fis-bamboo-agent-gitc-linux-cluster"
apply Service "disk-space-gitc-cluster" {
apply Service "memory-gitc-cluster" {
