in the official documentation I read about the possibility to set the constant “MaxConcurrentChecks” in constants.conf
Is it possible to set the number of simultaneous controls for a specific service?
For example, can I check “hostalive” one at a time on the hosts that Icinga is monitoring?
If I understand you correctly, you want to restrict how many checks are run simultanously? That’s set globally and you can’t set it per check or per plugin. So you can’t decide if the checks are pings, SQL health checks or webserver checks. It just sets globally how many checks (hosts and services added up) are run in parallel. This is only useful for very small or very huge environments.
But as @theFeu asked: Maybe you can tell us a bit more?
Could you please take the time to click the checkbox with “solution” in the post that gave the right answer? This way you give kudos and show other users that you don’t need any more help.
