I have a monitoring host set up, hpc-monitoring, and clients like ddn07.hpc.edu set up in a zone:
[root@hpc-monitoring icinga2]# cat zones.conf
* on 2020-01-27 15:08:39 -0800
object Endpoint "hpc-monitoring.hpc.edu" {
object Zone "master" {
endpoints = [ "hpc-monitoring.hpc.edu" ]
global = true
global = true
[root@hpc-monitoring master]# pwd
/etc/icinga2/zones.d/master
[root@hpc-monitoring master]# cat ddn07.hpc.edu.conf
object Endpoint "ddn07.hpc.edu" {
object Zone "ddn07.hpc.edu" {
endpoints = [ "ddn07.hpc.edu" ]
parent = "master"
object Host "ddn07.hpc.edu" {
check_command = "hostalive"
address = "10.125.0.79"
vars.client_endpoint = name
If I go on my client and look at the debug.log I see messages like this. Why is it saying “Current zone master: ddn07.hpc.edu”? Why doesn’t it think hpc-monitoring is the zone master? The client and checks seem to work fine but there’s lots of activity in the log.
[2020-04-09 10:29:49 -0700] debug/ApiListener: Not connecting to Endpoint 'hpc-monitoring.hpc.edu' because we're already connected to it.
[2020-04-09 10:29:49 -0700] notice/ApiListener: Current zone master: ddn07.hpc.edu
[2020-04-09 10:29:49 -0700] notice/ApiListener: Connected endpoints: hpc-monitoring.hpc.edu (1)
