The Logo in the top left corner isn’t showing.
My apache host config
<VirtualHost *:80>
# The ServerName directive sets the request scheme, hostname and port that
# the server uses to identify itself. This is used when creating
# redirection URLs. In the context of virtual hosts, the ServerName
# specifies what hostname must appear in the request’s Host: header to
# match this virtual host. For the default virtual host (this file) this
# value is not decisive as it is used as a last resort host regardless.
# However, you must set it for any further virtual host explicitly.
ServerName icinga.bots.miraheze.wikiServerAdmin webmaster@localhost DocumentRoot /usr/share/icingaweb2/public # Available loglevels: trace8, ..., trace1, debug, info, notice, warn, # error, crit, alert, emerg. # It is also possible to configure the loglevel for particular # modules, e.g. #LogLevel info ssl:warn ErrorLog ${APACHE_LOG_DIR}/error.log CustomLog ${APACHE_LOG_DIR}/access.log combined # For most configuration files from conf-available/, which are # enabled or disabled at a global level, it is possible to # include a line for only one particular virtual host. For example the # following line enables the CGI configuration for this host only # after it has been globally disabled with "a2disconf". #Include conf-available/serve-cgi-bin.conf
RewriteEngine on
<Directory “/usr/share/icingaweb2/public”>
Options SymLinksIfOwnerMatch
AllowOverride None<IfModule mod_authz_core.c> # Apache 2.4 <RequireAll> Require all granted </RequireAll> </IfModule> <IfModule !mod_authz_core.c> # Apache 2.2 Order allow,deny Allow from all </IfModule> SetEnv ICINGAWEB_CONFIGDIR "/etc/icingaweb2" EnableSendfile Off <IfModule mod_rewrite.c> RewriteEngine on # modified base RewriteBase / RewriteCond %{REQUEST_FILENAME} -s [OR] RewriteCond %{REQUEST_FILENAME} -l [OR] RewriteRule ^.*$ index.php [NC,L] </IfModule> <IfModule !mod_rewrite.c> DirectoryIndex error_norewrite.html ErrorDocument 404 /error_norewrite.html </IfModule>
RewriteCond %{SERVER_NAME} =icinga.bots.miraheze.wiki
RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
vim: syntax=apache ts=4 sw=4 sts=4 sr noet’
Apache 2.4
PHP 7.3
Debian Buster
even https://icinga.bots.miraheze.wiki/img/icinga-logo-big-dark.svg also doesn’t work. Images are working fine for other subdomains.
