I have installed ICINGA on Ubuntu OS and it shows active ( running).
How do I login into the ICINGA WEB ?
you have to install and configure icingaweb2
Thanks for your response. Are you able to send me the steps ?
Hi @nsubbuu,
you can find the steps in Icinga web doc
