I have set the default login domain in icingaweb (/etc/icingaweb2/config.ini).
So it is not necessary to type the domain at login.
But now it is not possible to login with locale users. Is there a possibility to use both variants in parallel ? AD login by default domain and local accounts?
Your example is a domain login or not ? But how to login with a local user, when i have configured the default domain under Configuration → Application ?
