Limitations for monitoring/blacklist/properties
Hello everybody,
I have some hosts where I want to restrict the view of services for users.
User A should only have his host group (hostgroup_a)
and not user B’s (hostgroup_b) user A should not see user B’s http_check. is that feasible?
I have entered it under Icingaweb2 / Configuration / Authentication / monitoring / blacklist / properties for user A:
monitoring/blacklist/properties (hostgroup_name=B|service_name=Check HTTP)
But unfortunately it has no effect on the view of user A. User A still sees the HTTP check of user B.
Does anyone have a tip for me here. Thank you
you’re using the wrong restriction. monitoring/blacklist/properties is for custom variables. You want monitoring/filter/objects.
When I use monitoring/filter/objects with this Parameters it doesn’t work
(hostgroup_name=RedHat!_service_test_load)
I hope the Parameters: “Es sind Verknüpfungen (OR = |, AND = &, NOT = !) und Vergleiche (EQUAL =, NOT EQUAL = !=, GREATER = >, LESS = <, GREATER OR EQUAL = >=, LESS OR EQUAL = <=) möglich” are correct
I want use: “hostgroup_name=RedHat” + "NOT = ! " and the User should not see the Service “test_load”
How can I implement that …
