Ldap_connect(): Could not create session handle: Bad parameter to an ldap routine
Hello ,
i have set ldap in icingaweb 2 but getting this error “Could not create session handle: Bad parameter to an ldap routine” , all information regarding icinga, php version and authentication.ini , resources.ini are as follow :
icinga2 version
icinga2 - The Icinga 2 network monitoring daemon (version: r2.11.4-1)
Copyright © 2012-2020 Icinga GmbH (https://icinga.com/)
License GPLv2+: GNU GPL version 2 or later http://gnu.org/licenses/gpl2.html
System information:
Platform: Debian GNU/Linux
Platform version: 10 (buster)
Kernel: Linux
Kernel version: 4.15.0-112-generic
Architecture: x86_64
Build information:
Compiler: GNU 8.3.0
Build host: runner-ltrjqz9n-project-298-concurrent-0
Application information:
General paths:
Run directory: /run/icinga2
Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /var
Internal paths:
php version : 7.3
resources.ini:
[my_ad]
type = “ldap”
hostname = “ldaps://XXX.XXXXX.de”
port = 636
encryption = “starttls”
root_dn = “DC=xx,DC=int”
bind_dn = “xx@xx”
bind_pw = “xxx”
authentication.ini:
[auth_ad]
backend = msldap
resource = my_ad
please also include the version of Icinga Web 2.
If you’re using anything lower than v2.6.3 you’d have to upgrade. Otherwise PHP 7.3 is not supported.
If you’re already on Icinga Web 2 v2.6.3 or higher, please take a look in the log (/var/log/icingaweb2/icingaweb2.log) and show the full error (with stacktrace) that should be included there.
it is resolved , i changed encryption from starttls to ldaps now is working .
Icinga Web 2 Version: 2.8.1
