Hi
Does anyone have some experience or ideas to integrate kibana into Icingaweb2 analogous to the Grafana integration with the grafana module? I think about feeding the performance date into elastik and would like to make some kibana dashboards then. It would be nice, to have the kibana graphs directly in the icinga web gui.
Well, there was icingaweb2-module-elasticsearch, but its EOL and no more compatible with newer elasticsearch versions. What you can do is storing perfdata in elasticsearch v9.2+ with OTLPMetricsWriter. You can display them in IcingaDB Web with icingaweb2-module-perfdatagraphs and icingaweb2-module-perfdatagraphs-elasticsearch. And you might be able to do some kibana dashboards with those anyways.
Thanks for your replay.
I plan to use the OTLPMetricsWriter and perfdatagraphs, but I’m interested in an integration similar to the grafana modul to be able to see kibana graphs directly in icingaweb2. So you don’t have to switch to kibana.
Theres nothing available. Technically speaking, it might be possible to develop something. There is a blogpost on how to embed Kibana Dashboards: How to embed Kibana dashboards | Elastic Blog
For you, id recommend you to use perfdatagraphs to have graphs natively in icingadb web, and use action links on your hosts/services to link directly to a kibana dashboard.
there isn’t a kibana equivalent of the grafana module, so kibana dashboards themselves can’t be dropped into icinga web. with the otlp writer plus perfdatagraphs-elasticsearch, the graphs you do get inside icingadb web are perfdatagraphs’ own, not kibana ones.
I will give a try to perfdatapraphs and otlp writer, as it seems, that there is no web modul to embed kibana graphs into icingaweb2. When I would need embedding, maybe I can write a module for this.
