This use to work but has not for a number of updates to Icinga. Unfortunately I cannot pinpoint exactly when it stopped working as I tend to use “Inspect” when I work on new checks which occurs sporadically.
Some ideas on how to debug/fix this would be appreciated.
Interestingly ipl is actually 0.11.0 according to the VERSION file but for some reason it still reports as 0.5.0.
Is there a way to check when these modules have an update? I check and update the RPM’s when they become available, but these modules I had forgotten about after the original installation.
The ipl module is not necessary anymore with a version of Icinga Web above 2.8.x. You can remove it, especially since you upgraded the director now. If you also have the reactbundle module still installed, the same applies.
I had disabled the reactbundle module as I did see that it was no longer needed.
I just disabled ipl just now and all seems to be still working, so that is good.
Again thank you for the information and assistance.
