Hi
We compiled and installed icinga2 core successfully from source code. We are now about to install the icingaweb2 the same way.
Could you please throw some light to start the compilation of icingaweb2 ?
Thanks&Regards
Srinivas
Hi
Thanks&Regards
Srinivas
Why did you do that? In order to get support in here and also via partners, only packages from packages.icinga.com are supported.
