Can the IcingaDB component safely run on both master nodes or should their only be one active IcingaDB service? Is some additional configuration required for HA? I only could find IDO HA guides…
Jul 28 12:43:59 monit2 systemd[1]: Starting Icinga DB...
Jul 28 12:43:59 monit2 icingadb[263902]: Starting Icinga DB
Jul 28 12:43:59 monit2 icingadb[263902]: Connecting to database at ' mariadb1:0'
Jul 28 12:43:59 monit2 systemd[1]: Started Icinga DB.
Jul 28 12:43:59 monit2 icingadb[263902]: Connecting to Redis at 'localhost:6380'
Jul 28 12:44:02 monit2 icingadb[263902]: Waiting for Icinga 2 to write into Redis, please make sure you have started Icinga 2 and the Icinga DB feature is enabled
Jul 28 12:44:54 monit2 icingadb[263902]: Starting history sync
Jul 28 12:44:55 monit2 icingadb[263902]: heartbeat: Received Icinga heartbeat
Jul 28 12:44:55 monit2 icingadb[263902]: high-availability: Another instance is active
