Trying to run this cmd (which succeeds)… however it is stripping/removing the first template import.
Is it possible to create a host object with multiple imports?
sudo icingacli director host create “hostname” --json ‘{“imports":“icon_rhel_vhost”, “imports”:"unix”, “address”:“1.2.3.4”, “vars”:{“os”:“linux”, “disks”:{“disk”:“{}”}, “filesystem”:{“/”:{}, “/export”:{}, “/var”:{}, “/var/log”:{}}, “client_endpoint”:“name”, “program”:“poc”, “location”:“somewhere”, “type”:“virtual”}}’
Output:
[user@icinga01 2468]$ sudo icingacli director host show hostname
object Host "hostname" {
import "unix"
address = "1.2.3.4"
vars.client_endpoint = "name"
vars.disks = {
disk = "{}"
vars.filesystem = {
"/export" = {}
"/var" = {}
"/var/log" = {}
vars.location = "somwhere"
vars.os = "linux"
vars.program = "poc"
vars.type = "virtual"
