Icinga2 with Gitlab integrations
Are there any integration for Icinga2 into Gitlab? Please advise. We use Gitlab almost exclusively and would like to tie in certain alerts with Gitlab to generate an issue.
  • Icinga Web 2 - 2.9.5
  • Runing on CentOS 7.8
  • director, doc, monitoring, incubator
  • Icinga Web 2 - 2.95
Thank you,
You could write a small script, which uses the gitlab api to create a new issue and define it as Notification Command and create a notification rule.
Basically the same as described in icingaweb2-module-jira/10-Notifications.md at master · Icinga/icingaweb2-module-jira · GitHub but with your own Notification Plugin
