Need some help. After installing Icinga2 I am not able to enable features. The following is the message I receive:
root@icingaserver:/tmp# icinga2 feature list
bash: icinga2: command not found
Please advise
to help you to find the problem we need more details. Which operating system you are using? What installation steps did you take? Have you installed from source or from the provided packages at http://packages.icinga.com?
Best regards
Hi Michael,
This is the version of Debian I am using:
Linux icingaserver 4.19.0-5-686 #1 SMP Debian 4.19.37-5+deb10u2 (2019-08-08) i686
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
You have new mail.
Last login: Fri Nov 8 19:21:28 2019 from 192.168.1.111
wrivera@icingaserver:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 10 (buster)
Release: 10
Codename: buster
I used the traditional download method thru the Packages in icinga.
The following are the packages used to install Icinga:
deb https://packages.icinga.com/debian icinga-buster main
deb-src https://packages.icinga.com/debian icinga-buster main
After install the software I discovered that I could not check any icinga daemon commands.
This is the result when I try to check “icinga2 feature list”
wrivera@icingaserver:/$ icinga2 feature list
-bash: icinga2: command not found
Let me know if I missed a step in the install that is causing this anomality.
Wilfredo rivera
Hello
Can you show us the command you used to install the the installed packages ( dpkg -l icinga ) ?
