Thanks in advance for reviewing my dilemma. I believe I’ve got icinga2 working just fine using ido_mysql. Please see the attached jpegs as a reference for the type of install i’m trying to accomplish.
For reference here’s all the features in icinga2 I have enabled ->
[user@ije00897 ~]# icinga2 feature list
Disabled features: compatlog debuglog elasticsearch gelf graphite icingadb influxdb livestatus opentsdb perfdata statusdata syslog
Enabled features: api checker command ido-mysql mainlog notification
[user@ije00897 ~]#
My hosts are all RHEL7 hosts. My php environment is PHP7.4.4 installed via the remi repos. Php is served via Nginx using PHP-FPM. My nginx version is ->
[root@ije00897 ~]# nginx -v
nginx version: nginx/1.17.9
[root@ije00897 ~]#
Here are all the php and ZendFramework modules installed via yum ->
[ije00897 ~]# yum list installed | grep php
icingaweb2-vendor-lessphp.noarch 2.7.3-1.el7.icinga
php.x86_64 7.4.4-1.el7.remi
php-Icinga.noarch 2.7.3-1.el7.icinga
php-ZendFramework.noarch 1.12.20-1.el7
php-ZendFramework-Auth-Adapter-Ldap.noarch
php-ZendFramework-Cache-Backend-Apc.noarch
php-ZendFramework-Cache-Backend-Libmemcached.noarch
php-ZendFramework-Cache-Backend-Memcached.noarch
php-ZendFramework-Captcha.noarch 1.12.20-1.el7
php-ZendFramework-Db-Adapter-Firebird.noarch
php-ZendFramework-Db-Adapter-Mysqli.noarch
php-ZendFramework-Db-Adapter-Pdo.noarch
php-ZendFramework-Db-Adapter-Pdo-Mssql.noarch
php-ZendFramework-Db-Adapter-Pdo-Mysql.noarch
php-ZendFramework-Db-Adapter-Pdo-Pgsql.noarch
php-ZendFramework-Dojo.noarch 1.12.20-1.el7
php-ZendFramework-Feed.noarch 1.12.20-1.el7
php-ZendFramework-Ldap.noarch 1.12.20-1.el7
php-ZendFramework-Pdf.noarch 1.12.20-1.el7
php-ZendFramework-Search-Lucene.noarch
php-ZendFramework-Serializer-Adapter-Igbinary.noarch
php-ZendFramework-Services.noarch 1.12.20-1.el7
php-ZendFramework-Soap.noarch 1.12.20-1.el7
php-ZendFramework-extras.noarch 1.12.20-1.el7
php-ZendFramework-full.noarch 1.12.20-1.el7
php-bcmath.x86_64 7.4.4-1.el7.remi
php-cli.x86_64 7.4.4-1.el7.remi
php-common.x86_64 7.4.4-1.el7.remi
php-devel.x86_64 7.4.4-1.el7.remi
php-fedora-autoloader.noarch 1.0.1-2.el7
php-fpm.x86_64 7.4.4-1.el7.remi
php-gd.x86_64 7.4.4-1.el7.remi
php-intl.x86_64 7.4.4-1.el7.remi
php-json.x86_64 7.4.4-1.el7.remi
php-ldap.x86_64 7.4.4-1.el7.remi
php-mbstring.x86_64 7.4.4-1.el7.remi
php-mysqlnd.x86_64 7.4.4-1.el7.remi
php-pdo.x86_64 7.4.4-1.el7.remi
php-pdo-dblib.x86_64 7.4.4-1.el7.remi
php-pdo-firebird.x86_64 7.4.4-1.el7.remi
php-pear.noarch 1:1.10.10-4.el7.remi
php-pecl-apcu.x86_64 5.1.18-1.el7.remi.7.4
php-pecl-apcu-bc.x86_64 1.0.5-3.el7.remi.7.4
php-pecl-apcu-devel.x86_64 5.1.18-1.el7.remi.7.4
php-pecl-igbinary.x86_64 3.1.2-1.el7.remi.7.4
php-pecl-imagick.x86_64 3.4.4-9.el7.remi.7.4
php-pecl-interbase.x86_64 1.0.0~DEV.20190523-4.el7.remi.7.4
php-pecl-mcrypt.x86_64 1.0.3-1.el7.remi.7.4
php-pecl-memcache.x86_64 4.0.5.2-1.el7.remi.7.4
php-pecl-memcached.x86_64 3.1.5-1.el7.remi.7.4
php-pecl-msgpack.x86_64 2.1.0-1.el7.remi.7.4
php-pecl-zip.x86_64 1.18.0-1.el7.remi.7.4
php-pgsql.x86_64 7.4.4-1.el7.remi
php-process.x86_64 7.4.4-1.el7.remi
php-soap.x86_64 7.4.4-1.el7.remi
php-sodium.x86_64 7.4.4-1.el7.remi
php-xml.x86_64 7.4.4-1.el7.remi
The Nginx host configuration is ->
server {
listen 80;
listen [::]:80;
server_name blah.blah;
return 301 https://$server_name$request_uri;
server {
listen 443 ssl http2;
listen [::]:443 ssl http2;
include /etc/nginx/snippets/self-signed.conf;
include /etc/nginx/snippets/ssl-params.conf;
include /etc/nginx/snippets/brotli.conf;
add_header Strict-Transport-Security “max-age=63072000; includeSubdomains; preload”;
index index.php;
root /ast/icingaweb2/public;
error_log /var/log/nginx/error.log;
location = /favicon.ico {
log_not_found off;
access_log off;
expires max;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
location ~ /\. {
deny all;
access_log off;
log_not_found off;
location ~ \..*/.*\.php$ {
return 403;
if (!-d $request_filename) {
rewrite ^/(.+)/$ /$1 permanent;
location / {
try_files $1 $uri $uri/ /index.php$is_args$args;
location ~ ^/index\.php(.*)$ {
fastcgi_index index.php;
include fastcgi_params;
try_files $uri =404;
fastcgi_split_path_info ^(.+\.php)(/.+)$;
fastcgi_pass unix:/run/php-fpm/www.sock;
fastcgi_param SCRIPT_FILENAME /ast/icingaweb2/public/index.php;
fastcgi_param ICINGAWEB_CONFIGDIR /etc/icingaweb2;
fastcgi_param REMOTE_USER $remote_user;
location ~ ^/icingaweb2/index\.php(.*)$ {
location ~ ^/icingaweb2(.+)? {
alias /ast/icingaweb2/public;
index index.php;
try_files $1 $uri $uri/ /icingaweb2/index.php$is_args$args;
I have setup icingaweb2 manually using the instructions at icinga.com/docs/icingaweb2/latest/doc/20-Advanced-Topics/t . The problem is … when I visit .blah.blah.com/info.php I see ->
Fatal error : Uncaught ErrorException: Uncaught Zend_Controller_Dispatcher_Exception: Invalid controller specified (error) in /usr/share/icingaweb2/library/vendor/Zend/Controller/Dispatcher/Standard.php:244 Stack trace: #0 /usr/share/php/Icinga/Web/Controller/Dispatcher.php(56): Zend_Controller_Dispatcher_Standard->dispatch(Object(Icinga\Web\Request), Object(Icinga\Web\Response)) #1 /usr/share/icingaweb2/library/vendor/Zend/Controller/Front.php(937): Icinga\Web\Controller\Dispatcher->dispatch(Object(Icinga\Web\Request), Object(Icinga\Web\Response)) #2 /usr/share/php/Icinga/Application/Web.php(300): Zend_Controller_Front->dispatch(Object(Icinga\Web\Request), Object(Icinga\Web\Response)) #3 /usr/share/php/Icinga/Application/webrouter.php(99): Icinga\Application\Web->dispatch() #4 /ast/icingaweb2/public/index.php(4): require_once(’/usr/share/php/…’) #5 {main} Next Zend_Controller_Exception: Invalid controller specified (error)#0 /usr/share/php/Icinga/Web/Controller/Dispatcher.php(56): Zend_Controller_Dispatcher_Standard->d in /usr/share/icingaweb2/library/vendor/Zend/Controller/Plugin/Broker.php on line 259
Any ideas where I’ve goobered this up? Many thanks in advance
dokon
(David Okon)
March 30, 2020, 10:12am
4
Hi James,
Is this the complete NGINX Configuration, just asking … is there any other active nginx config left (mostly default config maybe) …
If you can re-affirm that’s all config you have i can try to rebuild the setup and see where the nginx config doesn’t work properly.
Regards
David
dokon
(David Okon)
March 31, 2020, 7:32am
5
My solution at this point, cause you haven’t answered yet.
Is the following i’ve used an centos 7 vagrant box so there shouldn’t be a problem with rhel to reproduce it at this point.
Relatively plain install:
yum install epel-release -y
yum install centos-release-scl -y
yum update -y
yum install nginx -y
yum install rh-php71-php-fpm -y
sed -i 's/=enforcing/=permissive/g' /etc/selinux/config
setenforce 0 <= just for the actual session
rpm --import https://packages.icinga.com/icinga.key
yum install https://dl.fedoraproject.org/pub/epel/epel-release-latest-7.noarch.rpm
yum install icingaweb2 -y
mv /etc/nginx/nginx.conf /etc/nginx/nginx.old
==> Here a small inbetween step the rh-php71-php-fpm daemon needs to run for the fpm-uri
systemctl enable rh-php71-php-fpm --now && netstat -tulpn | grep php-fpm
icingacli setup config webserver nginx --document-root /usr/share/icingaweb2/public --config /etc/icingaweb2 --fpm-uri 127.0.0.1:9000 > /etc/nginx/nginx.conf
This Above just creates a base block of nginx config … there is still missing the essential part.
The base block looks like this:
fastcgi_pass 127.0.0.1:9000;
include /etc/nginx/fastcgi_params; <== this can change and needs adjustment
fastcgi_param SCRIPT_FILENAME /usr/share/icingaweb2/public/index.php;
alias /usr/share/icingaweb2/public;
index index.php;
With an Editor of you choice you need to add the following parts:
events {
worker_connections 1024; ## Default: 1024
http {
server {
listen 80;
root /usr/share/icingaweb2/public;
Just for the example i choose http not https.
So the whole nginx.conf block looks finalized like this:
events {
http {
server {
listen 80;
index index.php;
This should be validated with the nginx validator:
nginx -t -c /etc/nginx/nginx.conf
nginx: the configuration file /etc/nginx/nginx.conf syntax is ok
nginx: configuration file /etc/nginx/nginx.conf test is successful
I hope this helps with finding the error.
Regards
David
