Apparently secondary icinga2 node api is broken. I see these errors in the log. This is on Icinga2 2.5.4 cluster. The master is working fine. icinga2 daemon -C doesn’t show any error.
critical/SSL: Error on bio X509 AUX reading pem file '/var/lib/icinga2/ca/ca.crt': 33558530, "error:02001002:system library:fopen:No such file or directory"
[2019-11-19 12:17:13 -0800] warning/JsonRpcConnection: Error while processing message for identity 'sat1.test.com' Error: std::exception (0) libbase.so: void boost::throw_exception<icinga::openssl_error>(icinga::openssl_error const&) (+0x97) [0x7fb0d6d308a7]
(1) libbase.so: void boost::exception_detail::throw_exception_<icinga::openssl_error>(icinga::openssl_error const&, char const*, char const*, int) (+0x40) [0x7fb0d6d30950]
(2) libbase.so: icinga::GetX509Certificate(icinga::String const&) (+0x286) [0x7fb0d6ccb8a6]
(3) libremote.so: <unknown function> (+0xcf443) [0x7fb0d634c443]
(4) libremote.so: boost::detail::function::function_invoker2<icinga::Value (*)(boost::intrusive_ptr<icinga::MessageOrigin> const & boost::intrusive_ptr<icinga::Dictionary> const&), icinga::Value, boost::intrusive_ptr<icinga::MessageOrigin> const&,
boost::intrusive _ptr<icinga::Dictionary> const&>::invoke(boost::detail::function::function_buffer&,boost::intrusive_ptr<icinga::MessageOrigin> const&,
boost::intrusive_ptr<icinga::Dictionary> const&) (+0xf) [0x7fb0d639041f]
(5) libremote.so: icinga::ApiFunction::Invoke(boost::intrusive_ptr<icinga::MessageOrigin> const&, boost::intrusive_ptr<icinga::D
ictionary> const&) (+0x1d) [0x7fb0d633cb7d]
(6) libremote.so: icinga::JsonRpcConnection::MessageHandler(icinga::String const&) (+0x497) [0x7fb0d638a937]
(7) libremote.so: icinga::JsonRpcConnection::MessageHandlerWrapper(icinga::String const&) (+0x4b) [0x7fb0d638c00b]
(8) libbase.so: icinga::WorkQueue::WorkerThreadProc() (+0x492) [0x7fb0d6cdb542]
(9) libboost_thread.so.1.53.0: <unknown function> (+0xc5c3) [0x7fb0d77535c3]
(10) libpthread.so.0: <unknown function> (+0x7aa1) [0x7fb0d4b6caa1]
(11) libc.so.6: clone (+0x6d) [0x7fb0d48b993d]
Seems the quote thing doesn’t work well on here. I don’t see the directory /var/lib/icinga2/ca on the host
