I’m looking for tips and ideas on how to understand/troubleshoot an issue on my new icinga setup.
I did some research but haven’t found results.
I grep’ed to try and spot a redefinition but I can’t see it.
When I restart icinga2 on monitored servers, restart fails with the following message:
On server running the agent:
Feb 14 17:59:57 registry.int.mydomain.tld icinga2[11724]: [2021-02-14 17:59:57 +0100] information/cli: Icinga application loader (version: r2.8.1-1)
Feb 14 17:59:57 registry.int.mydomain.tld icinga2[11724]: [2021-02-14 17:59:57 +0100] information/cli: Loading configuration file(s).
Feb 14 17:59:57 registry.int.mydomain.tld icinga2[11724]: [2021-02-14 17:59:57 +0100] critical/config: Error: Object 'registry.int.mydomain.tld' of type 'Zone' re-defined: in /var/lib/icinga2/api/zones/registry.int.mydomain.tld/_et
Feb 14 17:59:57 registry.int.mydomain.tld icinga2[11724]: Location: in /var/lib/icinga2/api/zones/registry.int.mydomain.tld/_etc/registry.int.mydomain.tld.conf: 1:0-1:40
Feb 14 17:59:57 registry.int.mydomain.tld icinga2[11724]: /var/lib/icinga2/api/zones/registry.int.mydomain.tld/_etc/registry.int.mydomain.tld.conf(1): object Zone "registry.int.mydomain.tld" {
Feb 14 17:59:57 registry.int.mydomain.tld icinga2[11724]: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Feb 14 17:59:57 registry.int.mydomain.tld icinga2[11724]: /var/lib/icinga2/api/zones/registry.int.mydomain.tld/_etc/registry.int.mydomain.tld.conf(2): endpoints = [ "registry.int.mydomain.tld" ]
Feb 14 17:59:57 registry.int.mydomain.tld icinga2[11724]: /var/lib/icinga2/api/zones/registry.int.mydomain.tld/_etc/registry.int.mydomain.tld.conf(3): parent = "master.mon.int.mydomain.tld"
Feb 14 17:59:57 registry.int.mydomain.tld systemd[1]: icinga2.service: Main process exited, code=exited, status=1/FAILURE
Feb 14 17:59:57 registry.int.mydomain.tld systemd[1]: icinga2.service: Failed with result 'exit-code'.
On master:
# cat /etc/icinga2/zones.d/registry.int.mydomain.tld/registry.int.mydomain.tld.conf
object Endpoint "registry.int.mydomain.tld" {
host = "95.216.143.73"
object Host "registry.int.mydomain.tld" {
import "generic-host"
address = "95.216.143.73"
vars.http_vhosts["http"] = {
http_uri = "/"
vars.notification["mail"] = {
groups = [ "icingaadmins" ]
vars.client_endpoint = name
# icinga2 object list --type Zone
Object 'master.mon.int.mydomain.tld' of type 'Zone':
% declared in '/etc/icinga2/zones.conf', lines 11:1-11:20
* __name = "master.mon.int.mydomain.tld"
* endpoints = [ "master.mon.int.mydomain.tld" ]
% = modified in '/etc/icinga2/zones.conf', lines 12:3-12:26
* global = false
* name = "master.mon.int.mydomain.tld"
* package = "_etc"
* parent = ""
* source_location
* first_column = 1
* first_line = 11
* last_column = 20
* last_line = 11
* path = "/etc/icinga2/zones.conf"
* templates = [ "master.mon.int.mydomain.tld" ]
% = modified in '/etc/icinga2/zones.conf', lines 11:1-11:20
* type = "Zone"
* zone = ""
Object 'global-templates' of type 'Zone':
% declared in '/etc/icinga2/zones.conf', lines 24:1-24:30
* __name = "global-templates"
* endpoints = null
* global = true
% = modified in '/etc/icinga2/zones.conf', lines 25:3-25:15
* name = "global-templates"
* package = "_etc"
* parent = ""
* source_location
* first_column = 1
* first_line = 24
* last_column = 30
* last_line = 24
* templates = [ "global-templates" ]
% = modified in '/etc/icinga2/zones.conf', lines 24:1-24:30
* type = "Zone"
* zone = ""
Object 'node-1.prod-1.int.mydomain.tld' of type 'Zone':
% declared in '/etc/icinga2/zones.d/node-1.prod-1.int.mydomain.tld/node-1.prod-1.int.mydomain.tld.conf', lines 1:0-1:45
* __name = "node-1.prod-1.int.mydomain.tld"
* endpoints = [ "node-1.prod-1.int.mydomain.tld" ]
% = modified in '/etc/icinga2/zones.d/node-1.prod-1.int.mydomain.tld/node-1.prod-1.int.mydomain.tld.conf', lines 2:3-2:52
* global = false
* name = "node-1.prod-1.int.mydomain.tld"
* package = "_etc"
* parent = "master.mon.int.mydomain.tld"
% = modified in '/etc/icinga2/zones.d/node-1.prod-1.int.mydomain.tld/node-1.prod-1.int.mydomain.tld.conf', lines 3:3-3:42
* source_location
* first_column = 0
* first_line = 1
* last_column = 45
* last_line = 1
* path = "/etc/icinga2/zones.d/node-1.prod-1.int.mydomain.tld/node-1.prod-1.int.mydomain.tld.conf"
* templates = [ "node-1.prod-1.int.mydomain.tld" ]
% = modified in '/etc/icinga2/zones.d/node-1.prod-1.int.mydomain.tld/node-1.prod-1.int.mydomain.tld.conf', lines 1:0-1:45
* type = "Zone"
* zone = "node-1.prod-1.int.mydomain.tld"
Object 'node-1.preprod-1.int.mydomain.tld' of type 'Zone':
% declared in '/etc/icinga2/zones.d/node-1.preprod-1.int.mydomain.tld/node-1.preprod-1.int.mydomain.tld.conf', lines 1:0-1:48
* __name = "node-1.preprod-1.int.mydomain.tld"
* endpoints = [ "node-1.preprod-1.int.mydomain.tld" ]
% = modified in '/etc/icinga2/zones.d/node-1.preprod-1.int.mydomain.tld/node-1.preprod-1.int.mydomain.tld.conf', lines 2:3-2:55
* global = false
* name = "node-1.preprod-1.int.mydomain.tld"
* package = "_etc"
% = modified in '/etc/icinga2/zones.d/node-1.preprod-1.int.mydomain.tld/node-1.preprod-1.int.mydomain.tld.conf', lines 3:3-3:42
* source_location
* first_column = 0
* first_line = 1
* last_column = 48
* last_line = 1
* path = "/etc/icinga2/zones.d/node-1.preprod-1.int.mydomain.tld/node-1.preprod-1.int.mydomain.tld.conf"
* templates = [ "node-1.preprod-1.int.mydomain.tld" ]
% = modified in '/etc/icinga2/zones.d/node-1.preprod-1.int.mydomain.tld/node-1.preprod-1.int.mydomain.tld.conf', lines 1:0-1:48
* type = "Zone"
* zone = "node-1.preprod-1.int.mydomain.tld"
Object 'node-2.preprod-1.int.mydomain.tld' of type 'Zone':
% declared in '/etc/icinga2/zones.d/node-2.preprod-1.int.mydomain.tld/node-2.preprod-1.int.mydomain.tld.conf', lines 1:0-1:48
* __name = "node-2.preprod-1.int.mydomain.tld"
* endpoints = [ "node-2.preprod-1.int.mydomain.tld" ]
% = modified in '/etc/icinga2/zones.d/node-2.preprod-1.int.mydomain.tld/node-2.preprod-1.int.mydomain.tld.conf', lines 2:3-2:55
* global = false
* name = "node-2.preprod-1.int.mydomain.tld"
* package = "_etc"
% = modified in '/etc/icinga2/zones.d/node-2.preprod-1.int.mydomain.tld/node-2.preprod-1.int.mydomain.tld.conf', lines 3:3-3:42
* source_location
* first_column = 0
* first_line = 1
* last_column = 48
* last_line = 1
* path = "/etc/icinga2/zones.d/node-2.preprod-1.int.mydomain.tld/node-2.preprod-1.int.mydomain.tld.conf"
* templates = [ "node-2.preprod-1.int.mydomain.tld" ]
% = modified in '/etc/icinga2/zones.d/node-2.preprod-1.int.mydomain.tld/node-2.preprod-1.int.mydomain.tld.conf', lines 1:0-1:48
* type = "Zone"
* zone = "node-2.preprod-1.int.mydomain.tld"
Object 'node-3.preprod-1.int.mydomain.tld' of type 'Zone':
% declared in '/etc/icinga2/zones.d/node-3.preprod-1.int.mydomain.tld/node-3.preprod-1.int.mydomain.tld.conf', lines 1:0-1:48
* __name = "node-3.preprod-1.int.mydomain.tld"
* endpoints = [ "node-3.preprod-1.int.mydomain.tld" ]
% = modified in '/etc/icinga2/zones.d/node-3.preprod-1.int.mydomain.tld/node-3.preprod-1.int.mydomain.tld.conf', lines 2:3-2:55
* global = false
* name = "node-3.preprod-1.int.mydomain.tld"
* package = "_etc"
% = modified in '/etc/icinga2/zones.d/node-3.preprod-1.int.mydomain.tld/node-3.preprod-1.int.mydomain.tld.conf', lines 3:3-3:42
* source_location
* first_column = 0
* first_line = 1
* last_column = 48
* last_line = 1
* path = "/etc/icinga2/zones.d/node-3.preprod-1.int.mydomain.tld/node-3.preprod-1.int.mydomain.tld.conf"
* templates = [ "node-3.preprod-1.int.mydomain.tld" ]
% = modified in '/etc/icinga2/zones.d/node-3.preprod-1.int.mydomain.tld/node-3.preprod-1.int.mydomain.tld.conf', lines 1:0-1:48
* type = "Zone"
* zone = "node-3.preprod-1.int.mydomain.tld"
Object 'node-2.prod-1.int.mydomain.tld' of type 'Zone':
% declared in '/etc/icinga2/zones.d/node-2.prod-1.int.mydomain.tld/node-2.prod-1.int.mydomain.tld.conf', lines 1:0-1:45
* __name = "node-2.prod-1.int.mydomain.tld"
* endpoints = [ "node-2.prod-1.int.mydomain.tld" ]
% = modified in '/etc/icinga2/zones.d/node-2.prod-1.int.mydomain.tld/node-2.prod-1.int.mydomain.tld.conf', lines 2:3-2:52
* global = false
* name = "node-2.prod-1.int.mydomain.tld"
* package = "_etc"
% = modified in '/etc/icinga2/zones.d/node-2.prod-1.int.mydomain.tld/node-2.prod-1.int.mydomain.tld.conf', lines 3:3-3:42
* source_location
* first_column = 0
* first_line = 1
* last_column = 45
* last_line = 1
* path = "/etc/icinga2/zones.d/node-2.prod-1.int.mydomain.tld/node-2.prod-1.int.mydomain.tld.conf"
* templates = [ "node-2.prod-1.int.mydomain.tld" ]
% = modified in '/etc/icinga2/zones.d/node-2.prod-1.int.mydomain.tld/node-2.prod-1.int.mydomain.tld.conf', lines 1:0-1:45
* type = "Zone"
* zone = "node-2.prod-1.int.mydomain.tld"
Object 'node-3.prod-1.int.mydomain.tld' of type 'Zone':
% declared in '/etc/icinga2/zones.d/node-3.prod-1.int.mydomain.tld/node-3.prod-1.int.mydomain.tld.conf', lines 1:0-1:45
* __name = "node-3.prod-1.int.mydomain.tld"
* endpoints = [ "node-3.prod-1.int.mydomain.tld" ]
% = modified in '/etc/icinga2/zones.d/node-3.prod-1.int.mydomain.tld/node-3.prod-1.int.mydomain.tld.conf', lines 2:3-2:52
* global = false
* name = "node-3.prod-1.int.mydomain.tld"
* package = "_etc"
% = modified in '/etc/icinga2/zones.d/node-3.prod-1.int.mydomain.tld/node-3.prod-1.int.mydomain.tld.conf', lines 3:3-3:42
* source_location
* first_column = 0
* first_line = 1
* last_column = 45
* last_line = 1
* path = "/etc/icinga2/zones.d/node-3.prod-1.int.mydomain.tld/node-3.prod-1.int.mydomain.tld.conf"
* templates = [ "node-3.prod-1.int.mydomain.tld" ]
% = modified in '/etc/icinga2/zones.d/node-3.prod-1.int.mydomain.tld/node-3.prod-1.int.mydomain.tld.conf', lines 1:0-1:45
* type = "Zone"
* zone = "node-3.prod-1.int.mydomain.tld"
Object 'registry.int.mydomain.tld' of type 'Zone':
% declared in '/etc/icinga2/zones.d/registry.int.mydomain.tld/registry.int.mydomain.tld.conf', lines 1:0-1:40
* __name = "registry.int.mydomain.tld"
* endpoints = [ "registry.int.mydomain.tld" ]
% = modified in '/etc/icinga2/zones.d/registry.int.mydomain.tld/registry.int.mydomain.tld.conf', lines 2:3-2:47
* global = false
* name = "registry.int.mydomain.tld"
* package = "_etc"
% = modified in '/etc/icinga2/zones.d/registry.int.mydomain.tld/registry.int.mydomain.tld.conf', lines 3:3-3:42
* source_location
* first_column = 0
* first_line = 1
* last_column = 40
* last_line = 1
* path = "/etc/icinga2/zones.d/registry.int.mydomain.tld/registry.int.mydomain.tld.conf"
* templates = [ "registry.int.mydomain.tld" ]
% = modified in '/etc/icinga2/zones.d/registry.int.mydomain.tld/registry.int.mydomain.tld.conf', lines 1:0-1:40
* type = "Zone"
* zone = "registry.int.mydomain.tld"
Object 'director-global' of type 'Zone':
% declared in '/etc/icinga2/zones.conf', lines 36:1-36:29
* __name = "director-global"
* endpoints = null
* global = true
% = modified in '/etc/icinga2/zones.conf', lines 37:3-37:15
* name = "director-global"
* package = "_etc"
* parent = ""
* source_location
* first_column = 1
* first_line = 36
* last_column = 29
* last_line = 36
* templates = [ "director-global" ]
% = modified in '/etc/icinga2/zones.conf', lines 36:1-36:29
* type = "Zone"
* zone = ""
On both nodes, icinga2 is the one coming with ubuntu.
# icinga2 --version
icinga2 - The Icinga 2 network monitoring daemon (version: r2.8.1-1)
Copyright (c) 2012-2017 Icinga Development Team (https://www.icinga.com/)
Application information:
Installation root: /usr
Sysconf directory: /etc
Run directory: /run
Local state directory: /var
System information:
Platform: Ubuntu
Platform version: 18.04.5 LTS (Bionic Beaver)
Kernel: Linux
Kernel version: 4.15.0-135-generic
Architecture: x86_64
Build information:
Compiler: GNU 7.3.0
Build host: lcy01-amd64-027
On master:
# icinga2 daemon -C
information/ConfigItem: Committing config item(s).
information/ApiListener: My API identity: master.mon.int.mydomain.tld
warning/ApplyRule: Apply rule 'backup-downtime' (in /etc/icinga2/conf.d/downtimes.conf: 5:1-5:52) for type 'ScheduledDowntime' does not match anywhere!
warning/ApplyRule: Apply rule 'apt' (in /etc/icinga2/conf.d/apt.conf: 1:0-1:18) for type 'Service' does not match anywhere!
information/ConfigItem: Instantiated 1 ApiListener.
information/ConfigItem: Instantiated 10 Zones.
information/ConfigItem: Instantiated 8 Endpoints.
information/ConfigItem: Instantiated 1 ApiUser.
information/ConfigItem: Instantiated 2 FileLoggers.
information/ConfigItem: Instantiated 53 Notifications.
information/ConfigItem: Instantiated 1 NotificationCommand.
information/ConfigItem: Instantiated 210 CheckCommands.
information/ConfigItem: Instantiated 5 HostGroups.
information/ConfigItem: Instantiated 1 IcingaApplication.
information/ConfigItem: Instantiated 11 Hosts.
information/ConfigItem: Instantiated 1 UserGroup.
information/ConfigItem: Instantiated 1 User.
information/ConfigItem: Instantiated 4 TimePeriods.
information/ConfigItem: Instantiated 42 Services.
information/ConfigItem: Instantiated 3 ServiceGroups.
information/ConfigItem: Instantiated 1 CheckerComponent.
information/ConfigItem: Instantiated 1 ExternalCommandListener.
information/ConfigItem: Instantiated 1 IdoMysqlConnection.
information/ConfigItem: Instantiated 1 NotificationComponent.
information/ScriptGlobal: Dumping variables to file '/var/cache/icinga2/icinga2.vars'
information/cli: Finished validating the configuration file(s).
Thank you
P.S. When creating a new issue, the template mentions Troubleshooting - Icinga 2. This leads to a 404.
