Hello, I am using Icinga version 2.13.2-1. When I run the icinga2 node wizard on the master, the localhost host in the dashboard disappears and it does not appear on the added hosts in any way. I just see the below log.
debug/ApiListener: Not connecting to Endpoint ‘mydomain.com’ because the host/port attributes are missing.
While running the node wizard you were asked to enable or disable /etc/icinga2/conf.d and the default is to disable it. That’s the reason why the localhost disappeared. Depending on your setup you need now a new directory and include it in /etc/icinga2/icinga2.conf or in a subdirectory of /etc/icinga2/zones.d.
