Hi together, currently I have some issues with running icinga2 on a debian buster.
Installed everything via buster package manager, and configured it. After adding the latest buster icinga repos icinga2 updated to the lastest packages.
After updating all packages icinga is running in 2.7.* but it removed the icingacli package.
If I try to install icingacli again I am getting this message:
icingacli : Depends: php-icinga (= 2.6.2-3) but 2.7.3-1.buster is to be installed
But if I would do it like this many packages would be removed:
The following packages will be REMOVED:
icingaweb2 icingaweb2-common icingaweb2-module-monitoring
The following packages will be DOWNGRADED:
php-icinga
How do I get icingacli back on a buster debian with the current debian packages?
All modules based on running with icingacli are currently broken because of the missing package
Checked again and file was gone. … failed to our own infrastructure… something is deleting my sources.list.d entry … maybe puppet
… adding the list entry again and it is working…
Get:1 https://packages.icinga.com/debian icinga-buster/main amd64 icingacli all 2.7.3-1.buster [33.0 kB]
Well, if there is something from a 3rd Party that changes files on the system we can’t do anything about it.
It’s simply out of our hands but thanks for lettings us know.
Also Good luck in finding out what changes the sources.list.
