I’ve Icinga2 2.15.1-1 running with Icingaweb2 2.12.5 on Ubuntu 24.04 LTS. The command transport is Icinga2 API. Using IDO/Mysql with MariaDB-10.11.13. Also Livestatus enabled for “unix” socket and on a tcp port. The cluster hass a few satellite zones. It is not using director or icinga2 agent. LimitNOFILE=524288
This issue came up for the first time since the cluster was put in production 8 months ago. There was a service config change which required the icinga2 service reload. After reload, the service failed to accept connections even it was running on the config master.
[2026-08-28 15:03:48 -0700] information/Application: Received request to shut down.
[2026-08-28 15:03:48 -0700] information/Application: Shutting down…
[2026-08-28 15:03:48 -0700] information/CheckerComponent: ‘checker’ stopped.
[2026-08-28 15:03:48 -0700] information/NotificationComponent: ‘notification’ stopped.
[2026-08-28 15:03:48 -0700] information/DbConnection: ‘ido-mysql’ stopped.
[2026-08-28 15:03:48 -0700] information/LivestatusListener: ‘livestatus-tcp’ stopped.
[2026-08-28 15:03:50 -0700] critical/Socket: accept() failed with error code 9, “Bad file descriptor”
[2026-08-28 15:03:50 -0700] critical/LivestatusListener: Cannot accept new connection.
[2026-08-28 15:03:50 -0700] information/LivestatusListener: ‘livestatus’ stopped.[2026-08-28 15:03:50 -0700] critical/LivestatusListener: Cannot accept new connection.
[2026-08-28 15:03:50 -0700] information/ApiListener: ‘api’ stopped.
2026-08-28T15:03:15.951785-07:00 <maser1.com> safe-reload[2748274]: Validating config files: Done
2026-08-28T15:03:15.979336-07:00 <master1.com> safe-reload[2748274]: Reloading Icinga 2: Done
The secondary master reported this
[2026-08-28 15:03:50 -0700] information/ApiListener: Removing API client for endpoint <master1.com> 0 API clients left.
API client disconnected for identity <master1.com>
[2026-08-28 15:03:58 -0700] information/ApiListener: Reconnecting to endpoint <master1.com> via host <master1.com> and port ‘5665’
[2026-08-28 15:03:58 -0700] critical/ApiListener: Cannot connect to host <master1.com> on port ‘5665’: Connection refused [system:111 at /usr/include/boost/asi
o/detail/reactive_socket_connect_op.hpp:98 in function ‘do_complete’]
Any idea what could have gone wrong here? I understand that the livestatus is deprecated and we may move on to RestApi once the cluster gets updated to 2.16.5.
