I upgraded my Ubuntu 16.04 Server to Ubuntu 18.04 without issues (I wanted to test the new icingadb).
The Icinga2 Packages are also upgraded to 18.04 ones.
My only problem is with the graphite stats. In the cli I see, taht the whisper files still get updates but on the webfrontend I get count(): Parameter must be an array or an object that implements Countable
I found an older issue:
https://github.com/Icinga/icingaweb2-module-graphite/issues/168
but in my version im already using this patched version.
Here are the versions:
icinga2 - The Icinga 2 network monitoring daemon (version: r2.12.0-rc1-1)
Copyright (c) 2012-2020 Icinga GmbH (https://icinga.com/)
License GPLv2+: GNU GPL version 2 or later http://gnu.org/licenses/gpl2.html
There is NO WARRANTY, to the extent permitted by law.System information:
Platform: Ubuntu
Platform version: 18.04.4 LTS (Bionic Beaver)
Kernel: Linux
Kernel version: 4.15.0-101-generic
Architecture: x86_64Build information:
Compiler: GNU 8.3.0
Build host: runner-LTrJQZ9N-project-298-concurrent-0
OpenSSL version: OpenSSL 1.1.1 11 Sep 2018Application information:
General paths:
Run directory: /run/icinga2Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /varInternal paths:
Graphite Module Version 1.1
In the apache2 logs I dont see any issues.
Does anyone have an idear.
Greetings,
Epytir
