Using Icinga2 - 2.11.3 with master/secondary setup. The “cluster” service shows the endpoints count = Total count -1 . The icinga2 object list shows the correct total count.
It seems it doesn’t count the another master as endpoint when it checks the service. I would like to see the count matching. Is it by design or a bug or can it be fixed?
