I haven’t seen this issue before, and it’s pretty strange. I just updated Icinga2:
15:19UTC0 : [root@icinga /etc/icinga2/zones.d ]# yum history info 116 | grep icinga2 -B2
Updated icinga-php-library-0.6.1-1.el7.icinga.noarch @icinga-stable-release
Update 0.7.0-1.el7.icinga.noarch @icinga-stable-release
Updated icinga2-2.13.1-1.el7.icinga.x86_64 @icinga-stable-release
Update 2.13.2-1.el7.icinga.x86_64 @icinga-stable-release
Updated icinga2-bin-2.13.1-1.el7.icinga.x86_64 @icinga-stable-release
Updated icinga2-common-2.13.1-1.el7.icinga.x86_64 @icinga-stable-release
Updated icinga2-ido-mysql-2.13.1-1.el7.icinga.x86_64 @icinga-stable-release
Now, I’m receiving the following error when trying to restart services:
[2022-02-08 15:20:17 +0000] information/cli: Icinga application loader (version: 2.13.2-1)
[2022-02-08 15:20:17 +0000] information/cli: Loading configuration file(s).
[2022-02-08 15:20:17 +0000] critical/config: Error: Object 'mail-host-notification' of type 'NotificationCommand' re-defined: in /etc/icinga2/zones.d/global-templates/commands.conf: 9:1-9:51; previous definition: in /etc/icinga2/conf.d/commands.conf: 9:1-9:51
Location: in /etc/icinga2/zones.d/global-templates/commands.conf: 9:1-9:51
/etc/icinga2/zones.d/global-templates/commands.conf(7): */
/etc/icinga2/zones.d/global-templates/commands.conf(8):
/etc/icinga2/zones.d/global-templates/commands.conf(9): object NotificationCommand "mail-host-notification" {
/etc/icinga2/zones.d/global-templates/commands.conf(10): command = [ ConfigDir + "/scripts/mail-host-notification.sh" ]
/etc/icinga2/zones.d/global-templates/commands.conf(11):
[2022-02-08 15:20:17 +0000] critical/cli: Config validation failed. Re-run with 'icinga2 daemon -C' after fixing the config.
I’m unsure of why this is happening, it seems to be referencing itself stating that the object has been re-defined, by itself. I’ve double checked the file (commands.conf) but there’s no other explanation.
