I recently updated to icinga2 2.11.2-1 to take advantage of the new way icinga2 reloads. I noticed in the logs on a reload it still says its shuts everything down and restarts it. I just wanted to ask here to see if that is the desired behavior or if I am seeing something that should not be happening.
This is running on centOS 6.8
Here is an example of what I see (fyi, the time stamps were removed)
information/Application: Received request to shut down.
information/Application: Shutting down…
information/CheckerComponent: ‘checker’ stopped.
information/NotificationComponent: ‘notification’ stopped.
information/LivestatusListener: ‘livestatus’ stopped.
critical/Socket: accept() failed with error code 9, “Bad file descriptor”
critical/LivestatusListener: Cannot accept new connection.
information/ApiListener: ‘api’ stopped.
information/FileLogger: ‘main-log’ started.
information/ApiListener: ‘api’ started.
information/ApiListener: Started new listener on ‘[0.0.0.0]:5665’
information/LivestatusListener: ‘livestatus’ started.
information/LivestatusListener: Created UNIX socket in ‘/var/run/icinga2/cmd/livestatus’.
information/NotificationComponent: ‘notification’ started.
information/CheckerComponent: ‘checker’ started.
