Before you ask a question, you can check the troubleshooting documentation first, maybe you can find an answer here.
Hi Team,
Trying to Integrate Icinga2 with PagerDuty using the pg agent method. I am using the global event rule Integration Key in pagerduty-icinga2.conf but when the events reached the Icinga2 server its not forwarding to Pagerduty. Is there any integration guide. Not seeing any error in logs as well.
- Version used (
icinga2 --version) - 2.12.1-1 - Operating System and version - Cent OS 7
