Hi, I installed icinga2 on an Ubuntu 22. The following packages are installed:
- icinga2 (v: 2.13.5-1)
- icingaweb2 (v: 2.11.1, php: 8.1.2)
- icingadb
- icingadb-web (v: 1.0.0)
- icingadb-redis
- monitoring-utils
Everything went fine so far for monitoring localhost and showing the results in the web. As soon as i wanted to add an external agent i got stuck.
I executed the icinga2 node wizard
and then moved the following files into /etc/icinga2/zones.d/master
- app.conf
- apt.conf
- commands.conf
- downtimes.conf
- groups.conf
- hosts.conf
- notifications.conf
- services.conf
- templates.conf
- timeperiods.conf
- users.conf
Now my webinterface does not show any host left to monitor and the command icinga2 daemon -C
also shows no hosts to monitor, any hint where I did a mistake?
/etc/icinga2/icinga2.conf
include "constants.conf"
include "zones.conf"
include <itl>
include <plugins>
include <plugins-contrib>
include <manubulon>
include <windows-plugins>
include <nscp>
include "features-enabled/*.conf"
// Disabled by the node setup CLI command on 2022-09-09 07:56:45 +0200
//include_recursive "conf.d"
// Added by the node setup CLI command on 2022-09-09 07:56:45 +0200
include "conf.d/api-users.conf"
/etc/icinga2/zones.d/master/hosts.conf
object Host NodeName {
import "generic-host"
address = "127.0.0.1"
display_name = "Icinga2"
vars.os = "Linux"
vars.http_vhosts["http"] = {
http_uri = "/"
vars.http_vhosts["Icinga Web 2"] = {
http_uri = "/icingaweb2"
http_ssl = true
vars.disks["disk"] = {
/* No parameters. */
vars.disks["disk /"] = {
disk_partitions = "/"
vars.notification["mail"] = {
groups = [ "icingaadmins" ]
object Host "agent.fqdn.domain" {
address = "10.10.10.10"
display_name = "Agent-Host"
vars.os = "Windows"
vars.windows.version = "Windows Server 2019"
vars.agent_endpoint = name
/etc/icinga2/zones.conf
object Endpoint "master.fqdn.domain" {
object Endpoint "agent.fqdn.domain" {
host = "agent.fqdn.domain"
log_duration = 0
object Zone "master" {
endpoints = [ "master.fqdn.domain" ]
object Zone "agent.fqdn.domain" {
endpoints = [ "agent.fqdn.domain" ]
parent = "master"
global = true
global = true
Output of icinga2 daemon -C
[2022-09-09 10:20:08 +0200] information/cli: Icinga application loader (version: r2.13.5-1)
[2022-09-09 10:20:08 +0200] information/cli: Loading configuration file(s).
[2022-09-09 10:20:08 +0200] information/ConfigItem: Committing config item(s).
[2022-09-09 10:20:08 +0200] information/ApiListener: My API identity: master.fqdn.domain
[2022-09-09 10:20:08 +0200] information/ConfigItem: Instantiated 1 IcingaApplication.
[2022-09-09 10:20:08 +0200] information/ConfigItem: Instantiated 1 FileLogger.
[2022-09-09 10:20:08 +0200] information/ConfigItem: Instantiated 1 CheckerComponent.
[2022-09-09 10:20:08 +0200] information/ConfigItem: Instantiated 1 IcingaDB.
[2022-09-09 10:20:08 +0200] information/ConfigItem: Instantiated 4 Zones.
[2022-09-09 10:20:08 +0200] information/ConfigItem: Instantiated 2 Endpoints.
[2022-09-09 10:20:08 +0200] information/ConfigItem: Instantiated 2 ApiUsers.
[2022-09-09 10:20:08 +0200] information/ConfigItem: Instantiated 1 ApiListener.
[2022-09-09 10:20:08 +0200] information/ConfigItem: Instantiated 1 NotificationComponent.
[2022-09-09 10:20:08 +0200] information/ConfigItem: Instantiated 244 CheckCommands.
[2022-09-09 10:20:08 +0200] information/ScriptGlobal: Dumping variables to file '/var/cache/icinga2/icinga2.vars'
[2022-09-09 10:20:08 +0200] information/cli: Finished validating the configuration file(s).
Has anyone a hint what I did wrong? Do you need any further information?
Thanks in advance for your help!
