Hello all,
Icinga2 load Service Starts giving us warninn notification at 8% and critical at 10%. I have tried to change this from the config but it still remains the same. I want a Situation where we start getting warning from 80% and critical from 90%.
You can run icinga2 object list --type Service --name DC-M... this will tell you what the variable is set to and where it was set. Useful to check if it has been overwritten.
