Hi, is there a way to lengthen the time an agent is considered not connected? When I deploy changes via Director, I notice that checks happening < 1 minute after then report the agent is not connected but things bounce back fine shortly after.
Details and solution are under https://github.com/Icinga/icingaweb2-module-director/issues/1980. There are also some linked threads in this created issue that explain the reasons behind including or not including conf.d for your agents. NOT including conf.d is the default.
