Icinga GUI layout not working
please help icinga GUI not working .attaching log screenshot and icinga screenshot.
Pranav
It looks like you missed to update the database schema and migrate the preferences from file to database.
This was part of the upgrade to 2.9:
https://icinga.com/docs/icinga-web-2/latest/doc/80-Upgrading/#upgrading-to-icinga-web-2-29x
@dgoetz thanks for the reply this issue resolved , i have redeployed icinga on the server ,thanks for your help :slight_smile:
