Icinga director and error autoload.php
Hello
trying to configure icinga director an error occurred with the modules: ipl, reactbundle and incubator.
I download them from git and install them in the path: /usr/share/icingaweb2/modules
I change the names to the folders
trying to enable them I get this error
how can I solve that?
Hi
Please reconfigure the modules like below
#ipl
MODULE_NAME=ipl
MODULE_VERSION=v0.4.0
REPO=“https://github.com/Icinga/icingaweb2-module-${MODULE_NAME}
MODULES_PATH="/usr/share/icingaweb2/modules"
git clone ${REPO} “${MODULES_PATH}/${MODULE_NAME}” --branch “${MODULE_VERSION}”
icingacli module enable “${MODULE_NAME}”
cd /usr/share/icingaweb2/modules/ipl
git checkout ‘v0.4.0’
#reactbundle
MODULE_NAME=reactbundle
MODULE_VERSION=v0.6.0
cd /usr/share/icingaweb2/modules/reactbundle
git checkout ‘v0.7.0’
#incubator
MODULE_NAME=incubator
MODULE_VERSION=v0.3.0
cd /usr/share/icingaweb2/modules/incubator
git checkout ‘v0.5.0’
Regards
I had to use php composer.phar install to search for missing php files, now the modules are installed and enabled, but they don’t work
in the browser it puts me this route
http://192.168.1.81/icingaweb2/director/phperror/dependencies
the path on the server is
/usr/share/icingaweb2/modules/director/application/views/scripts/phperror#
inside phperror there are two files, dependencies.phtml and error.phtml
What can be?
Regards
Hi @Gonza
You should try to delete the modules are already installed and reinstall it again
please share the output while trying to enable the module
icingacli module enable modulname
For some reason it was not running git checkout correctly
Now it works correctly
Thank you
