How can i check with --no–ssl-certificate on certain plugins, if I donot want to check for ssl certificates.
Also when i check esxi hardware i have the below error. any suggestions would be appreciated.
UNKNOWN: ‘Connection to 172.68.76.213 timed out. (connect timeout=9.99)’
I am using check_esxi_hardware from nagios plugin. I have this issues.
File “/usr/local/lib/python2.7/dist-packages/pywbem/_cim_http.py”, line 494, in wbem_request
timeout=(HTTP_CONNECT_TIMEOUT, conn.timeout))
I have SSL enabled, and as per my guess somehow its redirecting to https, not sure if there is a way to ignore ssl with icinga
Enabled: true
Enabled Running SSLProtocols: tlsv1, tlsv1.1, tlsv1.2
Enabled SSLProtocols:
