Try log(Json.encode(m))
Json.encode(m) leads to “null” in the log file.
I think… nothing w/o knowing the complete host, service and command definitions this comes from.
Fair objection.
Many details are above already. What else do you want to see?
Maybe better via private msg/email?
Thanks,
Andy
Maybe the config even looks good, but an API query changes our minds.
Please log also macro("$host.name$")
and macro("$service.name$")
and share an API query result for that checkable.
[2020-07-15 13:27:54 +0200] information/config: Andy-DEBUG Start
[2020-07-15 13:27:54 +0200] information/config: null
[2020-07-15 13:27:54 +0200] information/config: cocodrilo.XXXX.de
[2020-07-15 13:27:54 +0200] information/config: Andy-Test
[2020-07-15 13:27:54 +0200] information/config: Andy-DEBUG End
Code:
object CheckCommand "andytest" {
command = [ PluginLocalDir + "/check_andytest" ]
arguments = {
"--warning" = {
value = "$andytest_warning$"
"--critical" = {
value = "$andytest_critical$"
"--perfparse" = {
// set_if = "$andytest_perfdata$"
set_if = () => { var m = macro("$andytest_perfdata$"); log("Andy-DEBUG Start"); log(Json.encode(m)); log( macro("$host.name$") ); log( macro("$service.name$") ); log("Andy-DEBUG End"); return m }
description = "Add performance data"
vars.andytest_perfdata = true
vars.andytest_warning = "15"
vars.andytest_critical = "5"
Query:
$ echo "get_service(\"cocodrilo.xxxx.de\", \"Andy-Test\").last_check_result.command" | ICINGA2_API_PASSWORD="xxxxx" /usr/sbin/icinga2 console --connect https://root@localhost:5665/
Icinga 2 (version: r2.11.4-1)
Type $help to view available commands.
<1> => get_service("cocodrilo.xxxx.de", "Andy-Test").last_check_result.command
[ "/usr/lib/nagios/plugins/check_by_ssh", "-C", "'/var/lib/nagios/plugins/check_andytest'", "-H", "127.0.0.1", "-p", "122", "-q", "-t", "90" ]
Result:
$ /usr/lib/nagios/plugins/check_by_ssh -C '/var/lib/nagios/plugins/check_andytest' -H 127.0.0.1 -p 122 -q -t 90
OK - Andy-Test passed.
Please share this one:
… and the host.
object Host NodeName {
import "generic-host"
address = "127.0.0.1"
address6 = "::1"
vars.os = "Linux"
vars.http_vhosts["http"] = {
http_uri = "/"
vars.http_vhosts["Icinga Web 2"] = {
http_uri = "/icingaweb2"
vars.http_vhosts["cocodrilo.xxxx.de"] = {
http_vhost = "cocodrilo.xxxx.de"
vars.disks["disk"] = {
vars.disk_wfree = "5%"
vars.disk_cfree = "3%"
vars.procs.procs_warning = 200
vars.procs.procs_critical = 250
vars.users.users_wgreater = 5
vars.users.users_cgreater = 10
object Service "Andy-Test" {
check_command = "andytest"
import "ssh-service"
host_name = "cocodrilo.xxxx.de"
Defining service objects without Apply Rule does not allow access of (host) variables. Details can be found here.
This doesn’t apply during check execution.
Thanks, interesting (and pretty weird) but I do have an apply rule.
Is there anything else you need to analyze this?
Maybe you guys just are on vacation?
Just a ping to remind that there still is an open question/issue.
No, waiting for you to provide the debug console outputs.
ciberandy:
… and the host.
I thought I did 18d ago:
ciberandy:
Andy-Test
object Host NodeName { import "generic-host" address = "127.0.0.1" address6 = "::1" vars.os = "Linux" vars.http_vhosts["http"] = { http_uri = "/" } vars.http_vhosts["Icinga Web 2"] = { http_uri = "/icingaweb2" } vars.http_vhosts["cocodrilo.xxxx.de"] = { http_vhost = "cocodrilo.xxxx.de" } vars.disks["disk"] = { } vars.disk_wfree = "5%" vars.disk_cfree = "3%" vars.procs.procs_warning = 200 vars.procs.procs_critical = 250 vars.users.users_wgreater = 5 vars.users.users_cgreater = 10 } object Service "Andy-Test" { check_command = "andytest" import "ssh-service" host_name = "cocodrilo.xxxx.de" }
If that’s not what you need, please let me know what else you want to see.
Thanks,
Andy
Uhm wait. Maybe you meant this?
<1> => get_service("cocodrilo.xxxx.de Andy-Test")
__name = "cocodrilo.xxxx.de!Andy-Test"
acknowledgement = 0.000000
acknowledgement_expiry = 0.000000
action_url = ""
active = true
check_attempt = 1.000000
check_command = "by_ssh"
check_interval = 600.000000
check_period = ""
check_timeout = null
command_endpoint = ""
display_name = "Andy-Test"
downtime_depth = 0.000000
enable_active_checks = true
enable_event_handler = true
enable_flapping = false
enable_notifications = true
enable_passive_checks = true
enable_perfdata = true
event_command = ""
extensions = {
DbObject = {
type = "Object"
flapping = false
flapping_buffer = 0.000000
flapping_current = 0.000000
flapping_index = 4.000000
flapping_last_change = 0.000000
flapping_threshold = 0.000000
flapping_threshold_high = 30.000000
flapping_threshold_low = 25.000000
force_next_check = false
force_next_notification = false
groups = [ ]
ha_mode = 0.000000
handled = false
host = {
__name = "cocodrilo.xxxx.de"
action_url = ""
active = true
address6 = "::1"
check_command = "hostalive"
check_interval = 60.000000
check_period = ""
display_name = "cocodrilo.xxxx.de"
event_command = ""
extensions = {
DbObject = {
type = "Object"
flapping = false
flapping_index = 18.000000
groups = [ "linux-servers
ha_mode = 0.000000
handled = false
icon_image = ""
icon_image_alt = ""
last_check = 1597097531.754861
last_check_result = {
active = true
check_source = "cocodrilo.xxxx.de"
command = [ "/usr/lib/nagios/plugins/check_ping -H 127.0.0.1 -c 5000,100% -w 3000,80%
execution_end = 1597097531.754768
execution_start = 1597097527.665351
exit_status = 0.000000
output = "PING OK - Packet loss = 0%, RTA = 0.06 ms"
performance_data = [ "rta=0.059000ms;3000.000000;5000.000000;0.000000 pl=0%;80;100;0
schedule_end = 1597097531.754861
schedule_start = 1597097527.664909
state = 0.000000
ttl = 0.000000
type = "CheckResult"
vars_after = {
attempt = 1.000000
reachable = true
state = 0.000000
state_type = 1.000000
vars_before = {
attempt = 1.000000
reachable = true
state = 0.000000
last_hard_state = 0.000000
last_hard_state_change = 1584400993.462069
last_hard_state_raw = 0.000000
last_reachable = true
last_state = 0.000000
last_state_change = 1584400993.462069
last_state_down = 0.000000
last_state_raw = 0.000000
last_state_type = 1.000000
last_state_unreachable = 0.000000
last_state_up = 1597097531.754885
max_check_attempts = 3.000000
next_check = 1597097591.124902
notes = ""
notes_url = ""
original_attributes = null
package = "_etc"
pause_called = false
paused = false
previous_state_change = 1584400993.462069
problem = false
resume_called = true
retry_interval = 30.000000
severity = 8.000000
source_location = {
first_column = 0.000000
first_line = 1.000000
last_column = 19.000000
last_line = 1.000000
path = "/etc/icinga2/conf.d/hosts/cocodrilo.xxxx.de.conf"
start_called = true
state = 0.000000
state_loaded = true
stop_called = false
suppressed_notifications = 0.000000
templates = [ "cocodrilo.xxxx.de generic-host
type = "Host"
vars = {
disk_cfree = "3%"
disk_wfree = "5%"
disks = {
disk = {
http_vhosts = {
"CERT xxxx.de" = {
http_certificate = "27,15"
http_ssl = true
"Icinga Web 2" = {
"cocodrilo.xxxx.de" = {
http = {
http_uri = "/"
lm_sensors_nodrives = true
lm_sensors_sanitize = true
lmsensors = {
"Sensor Core0" = {
lm_sensors_high = "Core0=60,85"
"Sensor Core1" = {
lm_sensors_high = "Core1=60,85"
"Sensor Core2" = {
lm_sensors_high = "Core2=60,85"
"Sensor Core3" = {
lm_sensors_high = "Core3=60,85"
"Sensor temp1" = {
lm_sensors_high = "temp1=50,80"
"Sensor temp2" = {
lm_sensors_high = "temp2=50,80"
mysql_health_password = "XXXXXXXXXXXXX"
mysql_health_username = "nagios"
mysqlserver = 1.000000
netinterfaces = {
"netusage br0" = {
netusage_bandwidth = "1G"
netusage_interface = "br0"
"netusage tun0" = {
netusage_bandwidth = "100M"
netusage_interface = "tun0"
"netusage wg0" = {
netusage_interface = "wg0"
notification = {
mail = {
groups = [ "icingaadmins
os = "Linux"
procs = {
procs_critical = 250.000000
procs_warning = 200.000000
smartdiskchecks = {
"SMART Status HGST HTE721010A9E630 #1" = {
smart_attributes_device = "/dev/disk/by-id/ata-HGST_HTE721010A9E630_JR10036P0E2LSK"
"SMART Status HGST HTE721010A9E630 #2" = {
smart_attributes_device = "/dev/disk/by-id/ata-HGST_HTE721010A9E630_JR10036P0E3LAK"
swap = {
swap_cfree = 60.000000
swap_wfree = 65.000000
users = {
users_cgreater = 10.000000
users_wgreater = 5.000000
version = 0.000000
volatile = false
zone = ""
icon_image = ""
icon_image_alt = ""
last_check = 1597097016.168752
active = true
command = [ "/usr/lib/nagios/plugins/check_by_ssh -C '/var/lib/nagios/plugins/check_andytest' -H 127.0.0.1 -p 122 -q -t 90
execution_end = 1597097016.168688
execution_start = 1597097015.871149
output = "OK - Andy-Test passed."
performance_data = [ ]
schedule_end = 1597097016.168752
schedule_start = 1597097015.870000
state = 0.000000
ttl = 0.000000
vars_after = {
attempt = 1.000000
reachable = true
state = 0.000000
vars_before = {
attempt = 1.000000
reachable = true
state = 0.000000
last_hard_state_change = 1595163697.165764
last_state_change = 1595163697.165764
last_state_critical = 0.000000
last_state_ok = 1597097016.168774
last_state_unknown = 1595163638.835292
last_state_warning = 0.000000
max_check_attempts = 5.000000
name = "Andy-Test"
next_check = 1597097615.870000
notes = ""
notes_url = ""
package = "_etc"
paused = false
previous_state_change = 1595163697.165764
problem = false
retry_interval = 60.000000
severity = 8.000000
source_location = {
first_column = 1.000000
first_line = 157.000000
last_column = 26.000000
last_line = 157.000000
start_called = true
state = 0.000000
state_loaded = true
stop_called = false
templates = [ "Andy-Test ssh-service generic-service
type = "Service"
vars = {
by_ssh_arguments = {
arguments = [ ]
deprecated = false
name = "<anonymous>"
side_effect_free = false
type = "Function"
by_ssh_command = {
arguments = [ ]
deprecated = false
type = "Function"
by_ssh_port = "122"
by_ssh_quiet = 1.000000
by_ssh_timeout = 90.000000
original_check_command = "andytest"
version = 0.000000
volatile = false
zone = ""
I see in neither the host nor the service the custom var you’re missing – i.e. you actually didn’t set it.
That’s exactly the problem (the bug?)
I did set them as you can see in my posts before.
But icinga seems to ignore these lines. Why?
No clue either?
Does it help to open an official bug report?
