Hi
i defined event command for service/host aas per below syntax
event_command = “send_to_businesstool”
Now instead of below
object EventCommand “send_to_businesstool” {
command = [
“/usr/bin/curl”,
“-s”,
“-X PUT”
arguments = {
“-H” = {
value ="$businesstool_url$"
skip_key = true
“-d” = “$businesstool_message$”
vars.businesstool_url = “http://localhost:8080/businesstool”
vars.businesstool_message = “$host.name$ $service.name$ $service.state$ $service.state_type$ $service.check_attempt$”
How can i define event _command = python script , where python takes the input for host/service and reason of failure and do some business logic"
How can i implement this??
Mayank (AMdocs)
