my question is:
If my checks are late, how do i get notifications?
I found a tutorial online but didnt understand it
Could someone explain how i can konfigurate this?
edit: Im working with the director.
Moin-se
my question is:
Moin-se
Hi - why are your checks late? As a rule, checks are delayed to prevent notifications, e.g. during any downtimes you set. /kb
This is the right question, imo.
Does your server have a high load? Are there checks running very long blocking the queue?
Too many concurrent checks (in a short time)?
my checks can be late if for example the firewall is closed.
If someone activated the firewall to early or removed the needed port, i will not see this because the icinga dont send a message.
I’m confused?! ![]()
Why not just implement a check that tests the ports reachability? Or use something behind the FW to check reachability.
Sounds like a very complicated way what you are trying to achieve (“von hinten durch die Brust ins Auge” would be the German proverb
Da hab ich wohl den Wald vor lauter Bäumen nicht gesehen
I had this Idea and was too focused on it
To check the Port is a good Idea i will do it like this
